Author Topic: Modified open / partial streamlined  (Read 3471 times)
Offline jeffw
« on: March 22, 2012, 11:26:10 PM »
Hi please forgive this newby question.  If you have a sport bike say a CBR or a Ninja can you successfully get through tech and run the open class if you remove all the fairing. I know that it varies from bike to bike and what kind of job you do, but generally is it legal to attempt this
Offline ol38y
Re: Modified open / partial streamlined
« Reply #1 on: March 23, 2012, 12:08:09 AM »
Provide you meet all the other safety requirements that has been done many times before. Welcome!  :cheers:
Larry Cason
2010 BUB 1350 M-PG record
Offline 55chevr
« Reply #2 on: March 23, 2012, 06:01:39 AM »
Larry is correct ... the short answer is yes ... this is within the rules assuming it meets safety and the provisions of open bike rules.   Read the rules carefully for the event you are going to run.
Offline jeffw
« Reply #3 on: March 28, 2012, 10:58:58 PM »
Thanks guys
       Jeff
« Reply #4 on: March 29, 2012, 10:57:59 AM »
Be sure that none of the remaining duct work or brackets under the fairing proper could be interpreted as an aerodynamic advantage - if so, it must be removed.
Offline BVCBR
  • Pflum & Wagner Racing
    • Gotfastbikes.com
« Reply #5 on: March 29, 2012, 11:12:24 AM »
The rules regarding the removal of OEM fairings and all the stuff that is left under those fairings were revised for the 2012 rule book. Be sure to get a copy and look at sections 7.F.11 for the Modified Production class. The last paragraph in section 7.F.11 is also new for 2012, but did not get the Bold lettering like the other revisions in that section.
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
