Had a visit from Nicholai (Fastlami) and a few of his mates, we also caught up with Ross and checked out the progress on his triple engine liner.
Was a good time and I look forward to seeing Nicholai's build, he has the skills to do the job looking at some of his and his friends current and previous projects.
Got a bit of time to do some work in my bike, been a little distracted lately.
Modified a shift drum to put Neutral on bottom so I can get an airshift to work reliably.
Trying to get Neutral which is a 1/2 shift between 1st and 2nd gears isn't going to happen with an airshift.
The standard drum has 5 shifts of 60 degrees each which made the job a fair bit easier. 2 shift-fork slots just needed extending by 1/2 a shift (30 degrees), the 3rd slot needed to ramp from 1st back to Neutral in the same distance.
The shift fork travels 6mm to go from Neutral to a gear, 6mm in 30 degrees = 1mm in 5 degrees so a bit of fiddling around then a bit of hand finishing with a die grinder came up ok.
Then moved the shift star locating dowel by 1 full shift (60 degrees);
Shift star bolted back on and fingers crossed and we have an Underhouse Engineering Neutral on bottom shift drum for a Hayabusa, you can see the 1/2 shift detent at the top of the star.
Have a wide ratio gearset dummied up in, will have a go at undercutting it and then test the shift drum.
Some tool steel shiftrods going in to help live with the shock of an airshift and that's all the mods the motor will get before the first year, I wouldn't have opened it at all if it wasn't for wanting Neutral in bottom.
Cheers
jon
