A slight hiccup in my build.
This went to vote and apparently got passed at SCTA meeting 3rd of November:
Current Rule:
Shall completely surround the rider and shall be fitted in the rider’s compartment. Minimum diameter is 1 1⁄4 inches with .090 inch nominal wall thickness, mechanical steel tubing. No galvanized pipe, black water pipe or threaded fittings are permitted. The design of the roll cage shall incorporate the following features as a minimum: Two (2) roll bars, (one forward and one after the riders head), which shall be tied together and capped with a steel plate .090 inches thick. The cap shall cover the upper 140 deg of the riders head. The roll bar shall be braced with a tube of the same dimensions on each side. Rider’s head movement shall be limited to no more than 2 inches to each side, top or rear with the riders head in the normal position. Roll cage padding meeting SFI specifications 45.1 for round tube roll cage padding and SFI specification 45.3 for flat cage padding is required in the vicinity of the rider’s
Issue:
Motorcycle streamliner and motorcycle side car streamliner roll cage tubing size requirements
Rulebook Section: 7.H.4 Rulebook Page No: 123
Desired Outcome:
To bring motorcycle streamliner and side car streamliner tubing and cage requirements in line with the car tubing requirements
Reason for Chg:
The current tubing sizes on some streamliners and side car streamliners (Speed X weight X Mass) is inadequate.
Side Effects:
None, (Will not affect any streamliner or side car streamliner that is currently running in the SCTA or BNI).
Desired Rulebook Wording:
Shall completely surround the rider and shall be fitted in the riders compartment. Minimum diameter is 1-1/4 in. with .090 in. nominal wall thickness, mechanical steel tubing in a vehicle with speeds under 175 mph. In vehicles with speeds over 175 mph minimum requirements for the roll cage structure and the roll cage structure braces are 1-5/8 in O.D. round steel tubing with a minimum .120 in. nominal wall thickness or E4130 chromoly tubing with a minimum .095 in. nominal wall thickness, securely mounted, gusseted and braced within 5 in. of the top of the roll cage structure. ALL ROLL CAGE STRUCTURES SHALL BE DESIGNED TO PROTECT THE DRIVER FROM ANY ANGLE, INCLUDING THE BOTTOM AND REAR. The front hoop of the roll cage shall be at least 3 in. in front of the drivers helmet while the driver is in his normal driving position.
It is my understanding and that of a couple well known current Streamliner Bike owners that it does not have a Grandfather rule and that it makes all current Streamliner Bikes and all but 1 Streamliner Bikes non compliant.
A fair few of us contacted the tech committee prior to the vote, to no avail apparently.
I've heard that Sam Wheeler (the benchmark in Streamliner Bikes IMHO) went with an engineer to the meeting, I've not talked to Sam since the vote.
This rule change request was apparently accompanied by this;
Issue:
Clarification/general information
Rulebook Section: 7.A.9 Rulebook Page No: 106 Desired Outcome:
To add same wording as shown in the car general requirements
Reason for Change:
Clarify the process of requesting deviations to current rule.
Side Effects:
None
Desired Wording:
Add 7.A.9: “ALL DEVIATIONS TO CURRENT ROLL STRUCTURE RULES SHALL BE SUBMITTED TO THE CONTEST BOARD NO LATER THAN 45 DAYS PRIOR TO THE EVENT FOR REVIEW.”
This appears to give an out to the 1 5/8" rule, just to confuse things further.
I believe that a properly built 1 1/4" rollcage on a bike will stand up to impact forces without significant deformation beyond what my body's internal organs can stand.
I welcome safety inspection on my bike, one of the main reason this build diary exists is for peer review.
See you on the salt, with my bike....
Jon
