May 18, 2013, 05:58:45 PM *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 ... 54   Go Down
Author Topic: Australian Streamliner Bike Build  (Read 41585 times)
saltwheels262
LORING 9/12
« Reply #195 on: April 17, 2012, 08:37:06 PM »
jon,
maybe it's me; but I don't see the difference in the pics in reply #193.
max 10/07 - a/pf   d license
bub '08 - 153.697 a/pf   pump gas
bub '09 - 156.377 aps/pf  ran out of gear
lta  '10 - 158.208  2 much gear 2x
                probably it for that mill, as is.
ohio - (1) 185.076 w/#684
          (2) 182.xxx w/20+ mph winds
lta  9/12  -148mph  in 3rd gear w/new #262 ( couldn't
                pull the rear gear in 4 much less 5 )
ohio - (4)  -153.x~in 4th.(+4 @the rear & leaving 1k+
      rpm on the table)
Jon
« Reply #196 on: April 17, 2012, 09:47:20 PM »
My Bad, Simpson Pro Rage;
I will be running petrol (Gas) until I need to run fuel to make more hp.
First year will be standard motor to settle bike and learn to ride.
Cheers
Jon
WOFTAM Racing, sponsored by Underhouse Engineering
Luck = Opportunity + Preparation
Jon
« Reply #197 on: April 22, 2012, 12:33:41 AM »
Been doing non bike stuff most of the weekend, helping stepfather inlaw move a bus he converting into a mobile home.
Redid the rails under my feet to drop my feet down and forward a little more;
Bottom rail closest is new rail, one on the other side is old rail.
Skinned the leg feet area;
The skin in this area is on the outside, skin in the seat area is on the inside.
It switches inside to outside at rail that goes down from the front rollbar tubes.
Tacks were still warm when i put on my SFI shoes and oversize test helmet;
It's the first time I've known 100% that I'm going to fit, I've sat in there and thought my foot was in the right spot but never been sure. Smiley
Cheers
jon
maguromic
« Reply #198 on: April 22, 2012, 12:41:42 AM »
Is that the tire between your legs?  Tony
Jon
« Reply #199 on: April 22, 2012, 03:51:16 AM »
Umm...yep Smiley
In a 2.5mm tub.
Anyone used a Go Power DA-512 dyno?
Think I just picked an old ratty one cheapish that I can upgrade next year if my bike is looking for more power rather than rebuilding bits.
Cheers
jon
maj
« Reply #200 on: April 22, 2012, 04:51:44 AM »
That the one in Gumtree ??
750 ft/lb should do it without upgrading
Jon
« Reply #201 on: April 22, 2012, 05:09:27 AM »
Yep; going to catch with the guy Wednesday Arvo.
If it's not stuffed mechanically I will just stash in under my table for a year so I don't get distracted.
Its a bellhousing mount but I will put it in a frame and run a jackshaft from the output shaft.
Cheers
jon
« Reply #202 on: April 22, 2012, 10:25:24 AM »
fitting in is NICE that is what we are doing on the lakester now making sure we still fit as we fiddle with adding the "systems" brakes, strg. throttle trans shifter guages  FIRESUIT shocked
WORDS to build by!
"--virtually the entire success of a turbo/engine system lies in thermal managemant."
 Corky Bell   MAXIMUM BOOST
" I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The great point is to bring them the real facts." A. Lincoln
agendadocumentary.com
« Reply #203 on: April 22, 2012, 08:43:25 PM »
Jon, I have a few pictures of Max's riders compartment to share with you.  I also have a question.  Where is the steering going to fit through the wheel well, will it still leave room the the legs in the firesuit.
The pictures
Looking forward from the front roll bar
Measurement of cockpit length at center of seat to front foot rest and throttle...
center of seat to handlebars (raised)
 MSA Lakester #1000 my fastest mile 245 and change, 84 ci turbobusa motor... but Corey's 233 MPH H/BFL record is still 3MPH faster than mine.
 Builder of Bike 278 1000cc APS-G,  Kids Red Hat Record 208.959 (old PS rules)
 Other kids A-G record 179.172  Josh O record 182.266
 Co-owner of the Amo Steele Streamliner, #1411... still sorting
« Reply #204 on: April 22, 2012, 08:55:50 PM »
More pics
floor to handlebars (raised position)
back headrest to front of bar
bottom of seat to roll bar
« Reply #205 on: April 22, 2012, 08:58:30 PM »
More pics
Floor to handlebars lowered
Front of bar to handlebars
Jon
« Reply #206 on: April 22, 2012, 10:19:05 PM »
Thanks very much for sharing Max and Stainless, I really appreciate it.
I will print them off and post some comparison measurements over the next few evenings.
The wheelwell will be welded into the frame and will be structural, the steering column will pivot from the top/rear of the wheelwell without going wider.
To change my front tyre the front yoke will be dropped out of the bottom of the bike.
Thanks again for your help.
jon
« Reply #207 on: April 23, 2012, 12:11:08 AM »
That is nice that you are fixing up a bus.  It reminds me of my hippie days.  I lived in a bus, too.
Jon
« Reply #208 on: April 25, 2012, 03:45:52 AM »
Picked up an old water brake dyno today, a Go-Power DA-512.
The guy I bought it off purchased it new in 1979 for apprentice training for a company that he was working for at the time.
Pulled the outlet plugs to see if there was much wear or cavitation inside;
Can still see the casting and machining marks inside Smiley
It used to live at Weipa, anyone who has been up that way will know that it is covered in fine red dust.
Going to clean it up, drown it in WD40 and stash it somewhere that its hard to get to so I don't get distracted.
Plan to put it back to close to original and tee in some data logging and have some weird ideas on load control that will have to wait.
Cheers
jon
« Reply #209 on: April 25, 2012, 07:29:38 AM »
 shocked  shocked now that is a FIND   shocked!!!
« Last Edit: April 25, 2012, 08:53:02 AM by SPARKY » Logged
WORDS to build by!
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 ... 54   Go Up
Google visited last this page May 16, 2013, 01:00:11 PM
