Thanks guys
It was no surprise to me the smoke came out of the TIG, it is one of the cheap fleabay 4 in 1 things.
I bought it a couple years ago cos i wanted to teach myself to TIG, for different reasons it just sat in the box until I started this a couple months ago, plugged it & nothing....
Pulled the cover off and was surprised how poor the quality control was, boards with big bows in them with an offcut of plastic wedged in to stop it vibrating, fan housing broken even though the packaging was undamaged.
I found the problem was a poorly crimped wire and new it was only a matter of time that it was going to die. When the smoke came out I pulled the cover off and decided to cut my losses, might fleabay it in case someone wants parts.
Bought a
Weldmaster 200p from a shop a few blocks away, he uses one himself and it's got 3 years waranty.
Tman; I think it was made by Ruucas Ercectrical
Peter Jack; i think I might give it to the local night school for they're electronics class, used to blow gear out regularly when growing up, our shed was dirt floor and it was a weekly ritual.
Stainless; Thanks, for some reason I thought the rules said 2 nozzles in the riders compartment, it doesn't, I will go back to one. I was plumbing my fire system in a continuos loop so everything coul feed from both ends, will check with tech here if I'm allowed to run a tap.
Is much happening to Black Lightning other than the engines? Would be great to see a thread on it again, the detail and finish is artwork.
Rex; Just water with something like dishwashing soap?
I think I must have bought my MIG/stick in about 1982, to adjust amperage it's got a jump cable that you swap between plugs, it's a SAFMIG mono bl. I toasted the capacitors in it about 5 years after I bought it making a scrub clearing blade for a bulldozer, replaced them with some bigger ones and a couple diodes and it's done the job since, it's worth fixing if it dies.
Hook in, today may be the best "one day" you have.
Oz; Thanks, I'm lucky they hadn't discovered ADHD or whatever it is when I was a kid, they would have pumped me full of pills, this project has got me going again, I hope to do some test runs on Lake Gairdner next year, I recon moving it from late March to mid January is a conspiracy started by Dr Goggles
Best go and do something.
jon
