Ok, gentlemen, I'd like to hear your opinion/experience on how to plumb a dry sump!
We have 2 diverse opinions on how we should do it. Obviously, one person is me, but to be fair to the team, we often fuss and discuss issues like this.
One person wants to put the filter on the pressure side, between the sump pump, and the block, which might be considered the 'traditional' way.
The argument:
The main issue is that if you restrict the scavenging of the pan, then you've defeated the purpose of the dry sump and you risk backing up the oil in the pan, the sump going dry and then losing the oil supply to the pressure stage of the pump and ultimately the engine.
The other person, wants to put the filter on the return side, after the pump, but before the oil tank reservoir, on the scavenger return line.
The argument:
With the filter on the scavenger return line, the reservoir does not become contaminated-you have clean oil in the reservoir, and clean oil going through the pressure side of the pump. with the filter on the pressure side,you are contaminating the reservoir, running it through the pump,then filtering that oil, before it goes to the engine.
How do you guys plumb them, and why?
