tauruck
« Reply #90 on: July 23, 2014, 11:52:21 PM » |
Awesome HRL. Not that surprising, it is a Ford after all.
horsewidower
New folks
Offline
« Reply #91 on: July 23, 2014, 11:58:56 PM » |
Fantastic.
Hot Rod Lincoln
Offline
« Reply #92 on: July 24, 2014, 09:39:03 AM » |
 Very nice, I'm impressed. How about posting the above over on turboford? Mike thanks .... You can post a link over there if you'd like. I'm not joining another forum for now. You should be able to get the photobucket link from the clip if you just want to post that. More progress to come in the next week.... Jon
lsrjunkie
Offline
« Reply #93 on: July 24, 2014, 11:56:44 AM » |
Maybe there is no Heaven. Or maybe this is all pure gibberish. The product of a demented hill billy who has found a way to live out where the winds blow. To sleep late, have fun, drink whiskey, and drive fast on empty streets with nothing in mind except falling in love or getting arrested. H.S. Thompson
Hot Rod Lincoln
Offline
« Reply #94 on: July 26, 2014, 10:45:26 PM » |
Scales today:    We figure the weight of the car is about 250 lbs light with not having everything bolted on. So approx 3,700. we are going to put 400 lbs in it to start keeping the drivers side 200 lbs lighter and having the weight approx 53/47 front/rear its 52% front heavy as it sits now. the race wheels and tires are off getting mounted and balanced
« Last Edit: July 26, 2014, 10:49:32 PM by Hot Rod Lincoln »
Hot Rod Lincoln
Offline
« Reply #95 on: July 27, 2014, 08:03:46 PM » |
new hood scoop. The mail box went bye bye:   going to have to do some work to get the air filter to mount up under the cowl, but should be able to pull it off.  going to run a 4" intake pipe along the intake plenum and have something like a blow-thru carb bonnet mounted to the turbo intake flange. the air filter will ride along the plenum up in the cowl hood. Gear choice made: have a few set's up and down from this: this should get us in the "ball park". a couple of shake down runs around 7,000 then we'll lean on it  9550
« Last Edit: July 27, 2014, 08:31:31 PM by Hot Rod Lincoln »
Hot Rod Lincoln
Offline
« Reply #96 on: July 29, 2014, 10:54:38 PM » |
well it's always something ....... what the hell happened to the wire loom ( relay pack) for the Motec ? Can't find it so one now has to be built  waiting for the schematic Air intake didn't work out as planned. 5" 90* hose won't fit. If the turbo was 1" to the left and the intake manifold 2" to the right all would be well. but it's not ... at least not this year.  Our fab guy is going to build an air box a bit like this: 8x11. 5" on the turbo side and 4.5" going to the air filter up in the cowl  we'll adjust as we go. it's always something.... Was looking at the mock-up this morning and figured out that the turbo system was missing something ..... the pipe running from the intercooler to the throttle body should have a BOV in it. something else to do.  9690
« Last Edit: July 29, 2014, 11:16:02 PM by Hot Rod Lincoln »
Hot Rod Lincoln
Offline
« Reply #97 on: July 31, 2014, 01:45:53 AM » |
260 of the 400 we are adding: a little bit of lead goes a long way  it's like Santa showed up today:  high octane good stuff A-8D 118 octane. Hopefully we'll be burning some on Monday or Tuesday night on the chassis dyno
Hot Rod Lincoln
Offline
« Reply #98 on: August 01, 2014, 07:49:42 PM » |
Today was one of those days were you actually got things accomplished but you feel like you just tread water:  Dry sump and radiator plumbed today. We pulled the intake to relocate the bungs so they will be out of the way for the 5" intake pipe and filter that will be installed. Wire loom will be installed tomorrow.
Sporty Dan
« Reply #99 on: August 01, 2014, 08:56:27 PM » |
You are making awesome progress on the car! I can't wait to see the numbers from the chassis dyno!
Hot Rod Lincoln
Offline
« Reply #100 on: August 10, 2014, 11:19:14 PM » |
Like so many others would love to be on the salt this week... a very bad deal for so many people We will have time to figure out a few things before we hit the salt. last week during out scramble to get together we learned a few things ...  ^^^ this set-up with the 5" pipes cost us 80 hp on the chassis dyno over this set-up:   ran on a local dyno with the "soft" tune up and just played with fuel psi:  put 640 to the ground with 20 psi boost and 21* timing. Now we have time to fine tune it and maybe add some boost and play with the timing. that muffler system is incredibly quite. we ran a 20' 5" section off the car exhaust, then split it into 2 4" pipes then into the muffler bank. Anyone have any in-put on Data loggers ? Edelbrock QwikData ? http://www.edelbrock.com/automotive/mc/qwikdata/racepak ? http://www.racepak.com/pro's / cons ? Temp: water, oil, air in, air out of intercooler Psi: oil psi, boost psi A/F RPM Wheel speed EGT. I'm guessing if you have the option get all four exhaust readings not just the collector ?
« Last Edit: August 10, 2014, 11:26:06 PM by Hot Rod Lincoln »
Hot Rod Lincoln
Offline
« Reply #101 on: November 28, 2015, 01:13:51 AM » |
It's been a while. Making some refinements: New manifold will allow space for air filter mounted to turbo. It has a bit more volume too    making some changes and hopefully be back on the chassis dyno early next year for some tuning
« Last Edit: November 28, 2015, 01:16:46 AM by Hot Rod Lincoln »
Calkins
Offline
On Any Sunday
« Reply #102 on: November 29, 2015, 09:27:22 PM » |
Man, I do love them Mark VIIIs!!! I have owned two in the past, and looking to get into another one sometime soon. I too have thought about building an VIII for Bonne. Someday... Here is some of my collection... Enjoy... Popular Hot Rodding - January 1993  Car Craft - February 1999  Super Ford - August 2000
Justin Calkins - Iowa Falls, Iowa USA
fastman614
Offline
« Reply #103 on: January 15, 2016, 02:49:09 AM » |
I just thought I would check in and see how you guys are doing.....the salt flats situation is kind of the big impediment right now for everyone, I guess...
The turbo engine sounds like a fast one!
Take care....
bbarn
Offline
« Reply #104 on: January 18, 2016, 12:37:19 PM » |
I'd like to know too!
I was standing with Rob this summer and a Lincoln pulled into the parking lot. It parked with a good profile view which caught my eye. I poked Rob and we talked about he aero of that body. I think one could do very well aerodynamically speaking with one of those.
