Author Topic: Radiator for "in tank" cooling system:  (Read 13022 times)
Re: Radiator for "in tank" cooling system:
« Reply #15 on: November 10, 2012, 07:57:17 PM »
I still have two of the 15x15 double pass units and one of the long narrow 24x4x3.5 radiators. If you are building something and want to go with the "radiator in a tank" cooling option both of these will work. Buddy, Flat Cad Racing, has had great luck with his. Give me a call: 707-484-5721 or E mail: rexschimmer@gmail.com.
Price is $150 each plus shipping.
« Reply #16 on: February 17, 2013, 06:15:58 PM »
Trent,
Here are a couple of pictures of the double pass radiator. Dimensions are 15 inches side to side and 15-1/2 across tank, 3-5/8 wide across tanks, core is 3 inch, connections are 1-1/2 and 1/3/8 inch. This is a double pass radiator so it works very well with lower flow water pumps. $150 plus shipping.
OK Rex, I NEED the 15x15, no way around it with the layout of the car. Any ideas on an intercooler similar that I can piggyback in the ice/water tank?
« Reply #17 on: February 17, 2013, 08:28:25 PM »
T man,
Give me a call or drop a personal E mail to me with your address and I will get it on the way. I don't have a contact for an intercooler , sorry.
« Reply #18 on: February 18, 2013, 09:42:08 PM »
Thanks Rex! Another part bought from a fellow racer here!~ :cheers:
Offline Captthundarr
  • In line
« Reply #19 on: February 18, 2013, 10:29:00 PM »
Rex, I have been considering the 24x4 for the wifes camaro C/GALTfor a while. I can't seem to keep it cool within reason. How big of a tank do you recon I would have to put it in, in your opion. We run the ECTA mile in wilmington.
Offline 38flattie
« Reply #20 on: February 20, 2013, 09:30:53 PM »
Frank, I have that same unit in a 20 gallon tank, and after 3 miles, it doesn't even melt half of the ice! I think I could run plain water, or use half of the size tank I have.
Don't forget, mine's a blown flathead, and still never gets over 185 degrees. It's one of the best things I bought for the car!
http://youtu.be/89rVb497_4c
  • In line
« Reply #21 on: February 20, 2013, 09:38:19 PM »
Thanks for the info Flattie, that helps. I have plenty of room for a 20 gal. tank. I'll do some calculations to see now small I can get away with.
« Reply #22 on: February 20, 2013, 10:08:31 PM »
Buddy --
We've got the same (or more) HP as you -- run 5 miles with less than 18 gal. and have never been over 185 either.  With no extra radiator and fittings to screw around with.
Stan
  • In line
« Reply #23 on: February 20, 2013, 10:12:53 PM »
Rex, PM Sent
Frank.
Offline CTX-SLPR
« Reply #24 on: February 20, 2013, 11:30:23 PM »
Are these limited supply items, as in "when they are gone, they're gone" or do you have them fabbed in batches?  Very interested in the 15x15 unit but money is a bit tight since I think I finally found a largely unmolested Regal to build.
Central TEXAS Sleeper
USAF Physicist
1964 Buick Riviera T-type (4.1L Turbo6, 4L80E, L67 EFI system)
ROA# 9790
« Reply #25 on: September 17, 2013, 07:38:31 PM »
I thought I would give this post a jack as there is renewed interest in the "radiator in a box" idea.
« Reply #26 on: September 28, 2013, 02:25:45 PM »
SOLD!!! Last one went to Montana for a flat motor.
I'll have to check with my supplier for more.
