Author Topic: New Liner Build, Fresno, CA  (Read 86821 times)
Offline landspeed55
Re: New Liner Build, Fresno, CA
« Reply #15 on: February 25, 2012, 05:19:28 PM »
Sorry!! Helps if Include the picture with the connection I was talking about
« Reply #16 on: February 25, 2012, 05:43:16 PM »
Trent, did you notice the fire bottle set up like I told you was a good idea when there is a space problem, BTW, in alll of my years I have never seen a frame failure in this area. Seen engines come out but no frame seperation.
Yes, noted on the bottles.
« Reply #17 on: February 25, 2012, 05:44:50 PM »
Hi Tman,
Good question. Hope you don't mind my long answer.
I am not sure if other chassis builders agree with the way I did this but, there is a good reason why I built it this way. In my opinion your doing great by thinking ahead incase of an event. You definitely have the right idea.
Take a look. You will notice a slight bend at each of the top rear compression frame rails just befor the tie in to those corner uprights. This bend provides a "weak" link. I perfer to call it a hinge.  This type of connection, by design, creates an area for deformation when subjected to high compression or tension forces. (Dynamic Energy Release) Hopefully diverting this energy from the driver.
Makes sense, thanks for your answer!
Offline robfrey
    • carbinitelsr
« Reply #18 on: February 26, 2012, 02:14:28 AM »
I thought all tubes in the driver area must be at least 1-5/8" in diameter. Looks like some tubes are smaller or is this just an illusion as the other bars 1-3/4?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline robfrey
    • carbinitelsr
« Reply #19 on: February 26, 2012, 02:16:14 AM »
Btw, nice build. That's a sexy body shape.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline mkilger
« Reply #20 on: February 26, 2012, 11:56:19 PM »
how wide are those gussets?  4in per side at all shoulder bar attachments points right? just look small that all
« Reply #21 on: February 27, 2012, 01:16:13 AM »
It looks to me that they washed the driveway just before he took that frame shot.
Attention to detail to the MAX.
« Reply #22 on: February 27, 2012, 06:12:35 PM »
    Or a rare rain day this year in Fresno, just a little over 3'' this season. One of several holding [flood ponds]
in Fresno in background.
   Good looking build. Some of our crew members have Hyabusas [sp] and dyno tune professionaly here in Fresno.
Offline landspeed55
« Reply #23 on: February 27, 2012, 08:40:23 PM »
Thanks. Gussets are all per the rule book.
Offline landspeed55
« Reply #24 on: February 29, 2012, 12:02:20 AM »
We dropped the liner off at Advanced Metal Works this morning. They will be working on the aluminum the rear body section. We will try to get some progress photos.
BB
http://landspeedstreamliner.weebly.com/
Offline landspeed55
« Reply #25 on: March 04, 2012, 09:35:48 PM »
Rear bearing carriers are almost finished. Still need to machine the rear wheel hubs, sprocket and break rotor hubs. I am sure looking forward to getting this thing on wheels. :cheers:
BB
Offline landspeed55
« Reply #26 on: March 07, 2012, 08:38:49 PM »
I stopped by Advanced Metal Works this afternoon and found the rear upper body panels are starting to take shape.
« Reply #27 on: March 07, 2012, 08:49:18 PM »
That is really looking great, super job by the tin benders for sure. :cheers:
Offline landspeed55
« Reply #28 on: March 14, 2012, 12:08:50 AM »
We recieved the new Tial Sport F40 wastegate today. Its a really nice piece. Thanks to Limit Engineering and GARRETT Turbochargers.
Offline donpearsall
    • http://soundappraisal.com
« Reply #29 on: March 14, 2012, 01:30:42 PM »
Beautiful work and good luck to you. But how come the NACA ducts are facing backwards?
