Just to play devils advocate here...
1. Entrant to go straight to impound - no brainer. Just requires policing or the old honesty system
2. So... are you requiring the
exactly same engine all season? Cause if your beef is $$, someone could spend lots of $$ to repair engines in a tight timeframe - if they were really serious. Restricting the engine classes just promotes sandbagging - which was the point of No. 3!?
To be in the running you need:
1. A competitive vehicle in whatever class.
2. The ability to break a record every meet - it might be just by a little, can be on same record
3. Consistently reliable vehicle
4. Ability to do a clean run, first pass, every meet. (seldom get a 2nd crack at it)
5. Really good luck.
6. Really bad luck for your opposition - What it seems to come down to is who makes the first mistake.
3. No GPS allowed in view of driver/rider for vehicles going for points champ -
Personally speaking here - El Mirage is so short, that I don't have the time to look at and read (yes they are different), a GPS. Too much going on. I get told if I'm at 9600 and in 6th gear by the time I go through the lights, I should be ok. Depending on what drama is happening that day (fire / spin / dust / messing up gear shift etc), I don't always know what the tach is either. Everyone is different. I don't have a dog in this fight.
