Author Topic: Utah Belly Tank  (Read 166848 times)
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
Re: Utah Belly Tank
« Reply #435 on: July 03, 2015, 10:25:49 AM »
That is a good thing :-D
Re: Utah Belly Tank
« Reply #436 on: July 03, 2015, 10:33:41 AM »
It's a wonder you didn't hear that clattering! Check the lifter & the lobe for damage.
So we're assuming the wet plug is dead cylinder fuel? :?
You might have to start running the valves during a meet until you know they're staying put.
Re: Utah Belly Tank
« Reply #437 on: July 03, 2015, 11:14:07 AM »
Sid, all of the above.  :wink: Wayno
Re: Utah Belly Tank
« Reply #438 on: July 03, 2015, 11:48:05 AM »
See you at the TnT Mate.
Re: Utah Belly Tank
« Reply #439 on: July 03, 2015, 11:53:02 AM »
I thought you might show up.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #440 on: July 03, 2015, 09:57:03 PM »
It's a pity those heads in your "parts room" are only plastic
Wazavudu Bellytank  Spirit of Sunshine Bellytank
Re: Utah Belly Tank
« Reply #441 on: July 03, 2015, 10:21:25 PM »
Not bringing the liner, just got the O/D's from B&J a couple of weeks ago. Going to help Steve with the big banana.
Re: Utah Belly Tank
« Reply #442 on: July 04, 2015, 02:54:17 PM »
OK. It looks like I got away with it. Everything looks, feels and measures bichin.  :-D I'll rig the adjuster so it won't take off and just do what it feels like.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #443 on: July 04, 2015, 05:32:07 PM »
Mark, there are no locknuts. I have considered that addition, though. When the parts store opens I'll have a look.  :wink: Wayno
Re: Utah Belly Tank
« Reply #444 on: July 05, 2015, 02:29:45 PM »
The parts store had no locknuts so I made one on my mill (12" Harbor Freight Disk Sander).  :cheers: Wayno
Offline ronnieroadster
Re: Utah Belly Tank
« Reply #445 on: July 05, 2015, 04:52:06 PM »
 Hi Wayno
   I always use locktite on the lifter adjuster threads I find that works perfectly even in our extreme environment on these all out racing flatheads. Even with a set of lifters that's already been run in oil and still in the block I just hit the treads with brake cleaner and set a drop on the lifter body the locktite still holds well. For extremely loose adjusters the green stuff will keep them in adjustment.
  For my flathead I check the valve adjustment after three good runs. That is if and when the speed gods allow three good runs in a row!  :-)
 Ron
« Last Edit: October 26, 2015, 11:54:14 AM by SPARKY »
 SCTA  XF/BGRMR Record 195.650
Re: Utah Belly Tank
« Reply #446 on: July 05, 2015, 05:22:38 PM »
Thanx Ronnie. It is noted. Are you coming to Speedweek? Wayno
Re: Utah Belly Tank
« Reply #447 on: July 05, 2015, 07:44:31 PM »
Yes Wayno I'm heading to Speed Week its time for me to get some salt on the race car tires and get my rookie runs in. My to do list is getting shorter each day but it seems there's still lots to do. Big project at the moment is to finish assembling the engine the internal parts from the engine I tested with this year are going into a fresh crack free 8BA block.Well its crack free until it runs at least.
 The must bring list is rather large with a 2400 mile journey ahead of us I want to be sure I have enough stuff to keep running and not leave anything behind. There's a group of us heading out so my support team will be large enough to help deal with whatever. My crew chief is my son without his help this would not take place and my wife is also coming with her support she makes this all happen. My wife gave the car its name the Mistress   :-)
Re: Utah Belly Tank
« Reply #448 on: July 05, 2015, 08:23:06 PM »
Cool. I'm looking forward to seeing your car and meeting up with you.  :cheers: Wayno
Offline Guardrail
  • Stan complained
Re: Utah Belly Tank
« Reply #449 on: July 23, 2015, 02:54:03 PM »
Hey Wayno,
 Since I'm gnu hear and a slow reader (ask Stan), I've finally read through this post. Knee-Toe.
Affiliate San Berdoo Roadsters
