Author Topic: Utah Belly Tank  (Read 155944 times)
Re: Utah Belly Tank
« Reply #420 on: June 21, 2015, 07:50:28 PM »
Following FB's advice... Pull the valve cover (intake manifold) and check the seal for damage
Dodge underhead valve motors have different terminology for the same thing  :roll: :cheers:
Re: Utah Belly Tank
« Reply #421 on: June 22, 2015, 06:50:27 AM »
It's all good Mark.  :wink: It is incumbent upon me to weed through "suggestions" for viability before doing any disassembly.  :-) Not only do I not have rocker covers, I don't have any rockers to cover. I woke up in the middle of the night to this revellation; The seals on the intakes on a Flathead Ford are on the body of the guide, not on the valve stem. So, "to the question "Do I have valve seals?" Not so much. The plot thickens. Wayno
Re: Utah Belly Tank
« Reply #422 on: June 22, 2015, 11:50:24 AM »
Stan, don't give up on the leakdown tester. It actually works, it's the instructions that are incorrect. I went to the HF site and read reviews of the tester and the proper procedure was outlined. My readings (cold) are pretty much in line with each other with the offending cylinder dead center on the values.  :-) I'll continue but I want to establish as many baseline values as I can. I'm learning. Wayno
Re: Utah Belly Tank
« Reply #423 on: June 24, 2015, 03:39:46 PM »
Mark, the leakdown readings (cold) were all fairly close in the 12% range. I'm waiting for some other things to happen before I can tear it down. It shouldn't be long. I did snake a tie wrap through the sparkplug hole on the offending cylinder and it came back with oil on the tip. OK. Not much information but it all adds up. Wayno
Offline saltracer1
Re: Utah Belly Tank
« Reply #424 on: June 24, 2015, 04:27:32 PM »
a wag is that it's sucking oil though a leak in the intake.
Offline Dynoroom
Re: Utah Belly Tank
« Reply #425 on: June 24, 2015, 04:50:12 PM »
Just more cannon fodder for you Wayno.
Since you have individual coils are you sure the plug is firing? If the spark plug is not firing it would allow oil in the cylinder but still keep leak down readings normal. Just a thought, should be easy to check before tearing stuff down.
Re: Utah Belly Tank
« Reply #426 on: June 24, 2015, 05:19:31 PM »
I have to pull the intake to adjust the valves so I'll keep my eyes peeled for evidence. I'll look into the coil too. Thanx guys.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #427 on: June 25, 2015, 11:26:21 PM »
Is the oil ring on the piston?  Us older guys sometime forget stuff.
Re: Utah Belly Tank
« Reply #428 on: June 26, 2015, 06:34:52 AM »
Yes. Wayno
Re: Utah Belly Tank
« Reply #429 on: June 26, 2015, 08:41:33 AM »
have you started digging for oil yet  :-D
Miss LIBERTY,  changing T.K.I.  to noise, dust and RUST!!!
           tncsg.org     mrspowell.org
ELECTION  INTEGRITY  PROJECT
eip-ca.com  EIPAz.org  eipnv.
Re: Utah Belly Tank
« Reply #430 on: June 26, 2015, 10:03:02 AM »
That should be later today. I had some other issues to sort and that happened last night.  :cheers: Wayno
Offline salt27
Re: Utah Belly Tank
« Reply #431 on: June 29, 2015, 10:03:18 PM »
Wayno, your killing us.   :?
Re: Utah Belly Tank
« Reply #432 on: June 30, 2015, 10:24:43 AM »
LOL. :-D  :evil:  :dhorse:
Offline PorkPie
  • think fast.....always
Re: Utah Belly Tank
« Reply #433 on: June 30, 2015, 11:05:03 AM »
.....and the winner is.... :-D :-D :-D :-D :-D
Photoartist & Historian & 200 MPH Club Member
Re: Utah Belly Tank
« Reply #434 on: July 03, 2015, 10:12:01 AM »
Progress. I pulled the head on the offending side and everything looked fine. I pulled the intake manifold and gave a cursory inspection and saw nothing wrong. No misplaced ( :wink:) oil or anything. Waitaminit. The intake valve is veeeery far from the lifter. Turns out the adjustable lifter had taken it upon itself to re- adjust itself to .117" instead of a more comfortable .012". I'll look to see if this caused any damage and go on from there. Next year maybe these adjustables will be gone. I'd like that. At least it's not pure mystery any more.  :cheers: Wayno
