Author Topic: Utah Belly Tank  (Read 165219 times)
Re: Utah Belly Tank
« Reply #390 on: March 11, 2015, 05:23:16 PM »
I'm betting he made it.
Past Member of the San Berdoo Roadsters -- "California's Most-Exclusive Roadster Club" -- Fifty-Seven Years of Leadership  Is Enough
No13
Re: Utah Belly Tank
« Reply #391 on: March 11, 2015, 06:40:49 PM »
Way cool.  Might have to build me a model of mine when I get it done.
Kelly
Offline NathanStewart
Re: Utah Belly Tank
« Reply #392 on: April 09, 2015, 03:18:36 PM »
Wayno, did you ever get to look at your logs?
El Mirage 200 MPH Club Member
Re: Utah Belly Tank
« Reply #393 on: April 09, 2015, 05:44:16 PM »
I'm getting closer, Nathan.  :roll: Now if I can get my printer to print the pages of instructions so I can take them out to the shop........Wayno
Re: Utah Belly Tank
« Reply #394 on: June 17, 2015, 06:37:07 AM »
OK. I finally got in a couple of decent passes at El Mirage so now I will have some data to build on. I ran 134 on Saturday and 136 on Sunday. Sunday's run was plagued by a miss and when we pulled the plugs there was oil on 3 of them. Rather than hurt the motor I pulled the plug. I figure I got what I needed so I'll get it sorted for Speed Week. I drove home happy.  :cheers: Wayno
  • After further investigation, I/GT record holder
Re: Utah Belly Tank
« Reply #395 on: June 17, 2015, 07:29:36 AM »
Oiling plugs?   :|
Glad you got the runs in, brother.  Salt Shakedown next month?
Re: Utah Belly Tank
« Reply #396 on: June 17, 2015, 07:39:43 AM »
Nope. Just getting ready for Speedweek.  :wink: Wayno
Re: Utah Belly Tank
« Reply #397 on: June 17, 2015, 08:22:43 AM »
I'm pulling for you Wayno. :cheers: :cheers: :cheers:
Re: Utah Belly Tank
« Reply #398 on: June 17, 2015, 09:53:44 AM »
Wayno, if it leaks down ok, pull the inkake & see if it's coming around the intake gasket.
Re: Utah Belly Tank
« Reply #399 on: June 17, 2015, 10:42:10 AM »
No leakdown yet. I just got it off the trailer yesterday. Leakdown is next.  :wink: Wayno
Re: Utah Belly Tank
« Reply #400 on: June 17, 2015, 01:09:27 PM »
fingers crossed!!!!!
Miss LIBERTY,  changing T.K.I.  to noise, dust and RUST!!!
           tncsg.org     mrspowell.org
ELECTION  INTEGRITY  PROJECT
eip-ca.com  EIPAz.org  eipnv.
Re: Utah Belly Tank
« Reply #401 on: June 17, 2015, 09:17:18 PM »
What are you running for rings?
Mark and I were talking last night about mapping EFI and ignition from scratch, which is what you're doing.
He mentioned that if you "rattle" the engine a little lean or with too much timing during dial in, with iron rings, you're more likely to break them.
Are all the oiled plugs on the same bank?
I'm hoping Sid is right.
Re: Utah Belly Tank
« Reply #402 on: June 17, 2015, 09:32:18 PM »
Synthetic oil?  if so, did you run it in with regular oil first?
Just stabbin' in the dark while you figure out what's going on.  :cheers:
Re: Utah Belly Tank
« Reply #403 on: June 18, 2015, 11:08:11 AM »
Mark, I am in a position to put some heat into it at this point and so shall. And thanx everyone. it is helpful.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #404 on: June 18, 2015, 02:04:06 PM »
Checking it cold is good enough to tell you "If" there's a problem & where it is without running it & possibly doing more damage.
And hurry the hell up Mate, we're obviously all hanging on the edge of our seat's here! :evil: :-D
