Author Topic: Utah Belly Tank  (Read 164679 times)
  • After further investigation, I/GT record holder
Re: Utah Belly Tank
« Reply #345 on: November 01, 2014, 01:14:57 PM »
Nate, I saw Gary's work on the tank in September, the evolution of the rest of the build, Wayno's ubercustom trick F1 style manifold, and then I saw it was in your hands.
Nate, I remain doubtless.  :cheers:
Offline NathanStewart
Re: Utah Belly Tank
« Reply #346 on: November 01, 2014, 06:47:33 PM »
Thanks Chris.   :wink:
El Mirage 200 MPH Club Member
Re: Utah Belly Tank
« Reply #347 on: November 11, 2014, 06:40:21 AM »
On Sunday I was pulling hard in third at about the mile when it shut off. According to data I was doing 135 at that time. I am encouraged because this is only the second pass on the new setup and I had a throttle stop set at 80%. By the way, I drove down last Monday because vacuum sucked the top of the plenum in on the dyno last Sunday. I effected the repairs and made it to the races. I'm home but whipped. When I say whipped, I just mean tired. I assure you, I ain't whipped. Wayno
Re: Utah Belly Tank
« Reply #348 on: November 11, 2014, 07:15:32 AM »
The one thing that bothers me about your sucking in the top of the plenum is that there must have been some restriction in the intake path to cause such a high vacuum. Have you looked into what caused the vacuum? Too small or too restrictive air cleaners are often the cause. There's definitely some horsepower hidden there.
Re: Utah Belly Tank
« Reply #349 on: November 11, 2014, 01:57:20 PM »
Pete, that would have been because the throttle body was closed. It is on the plenum and the first thing the air sees. There are no butterflies or anything after that. The air has a clear path to the valve. The failure was due to a problem with my building. I used aluminum pop rivets in a structural area. I forgot that aluminum pop rivets are merely decorative trim.  :roll: Wayno
Re: Utah Belly Tank
« Reply #350 on: November 11, 2014, 02:03:32 PM »
While I have your attention I'd like to point out that this week couldn't have happened without the help of Ray Federowicz, John Romero, Sparkplug Gary, Steve Otten, Nate Stewart, Mike Manghelli, Rick Yacoucci, Doug Robinson and Gus. They were all there when the chips were down. I owe 'em big.  :cheers: Wayno
« Last Edit: November 11, 2014, 02:19:23 PM by Elmo Rodge »
Re: Utah Belly Tank
« Reply #351 on: November 11, 2014, 03:54:13 PM »
You're right Wayno, aluminum "Pop" rivets are well named. All of us get caught out on that sort of thing once in a while. Most of us don't make the mistake the second time. It's called experience!  :-D :-D :-D
Offline lsrjunkie
Re: Utah Belly Tank
« Reply #352 on: November 11, 2014, 04:19:30 PM »
Glad to hear you made it Wayno! Hopefully you got some good info, and the old girl will really scream come next year!
Re: Utah Belly Tank
« Reply #353 on: November 11, 2014, 04:30:49 PM »
Elmo;
Try using AVEX rivets. They are far better than common Pop rivets but use the same tool to install them. Reasonable price from Aircraft Spruce.
Re: Utah Belly Tank
« Reply #354 on: November 11, 2014, 05:13:24 PM »
http://stuffnobodycaresabout.com/wp-content/uploads/2012/01/Cover-Whipped-Cream-and-Other-Delights.jpg
Hehehe, haw haw haw , hi Wayno, cherry anyone? :wink:
Re: Utah Belly Tank
« Reply #355 on: November 11, 2014, 05:26:16 PM »
Kind Doctor, sir.  Perhaps you'll explain to those of us north of you -- just what Herb Alpert's album cover has to do with Wayno's car.  I think I might still have that album. . .
Just yesterday I received the two new pieces of hardware for the 'puter.  One will hold 35mm slides for digitalising (my word) for the cormputer, and the other is a turntable so I can put the dozens, nay hundreds, of records into the machine here.  Just think:  I'll soon be able to listen to the Mystic Moods Orchestra and Benny Goodman's Carnegie Hall concert featuring the long version of "Sing, song, sing".  My complete collection of Jefferson Airplane and some Andy Warhol and "Power Tools" by I don't remember.  I searched and the machine came up with Ronald Shannon Jackson as the force behind the band, but I saw that it was a one and only album - and there was no song on it that I recognised.  I guess, therefore, it's time for me to submit this post.
« Last Edit: November 11, 2014, 05:36:45 PM by Seldom Seen Slim »
Re: Utah Belly Tank
« Reply #356 on: November 11, 2014, 05:34:32 PM »
Jon, I know the cold weather slows thinking.... Wayno was a little whipped.... if you need more help, ask Nancy
Re: Utah Belly Tank
« Reply #357 on: November 11, 2014, 05:41:23 PM »
Fortunately for us, the weather isn't cold during this snowy storm.  It's now evening -- and the temp has plummeted all the way down to 27F.  The problem with that is the snow is so wet and sticky that it clogs the output chute of the snow thrower repeatedly when I'm throwing the snow.  Frequently like three or four times with the little 'thrower - and again a few times with the bigger machine.  At least it didn't clog when I was using the BIG snow thrower -- the one that's 66" wide and powered by a 56 hp turbo diesel.  That one worked okay - 'cept that one leg of the electric control cable is farkled and so I couldn't re-aim or re-deflect the output.  Poo!
Re: Utah Belly Tank
« Reply #358 on: November 11, 2014, 06:02:26 PM »
Hey Stainless. Get off Slim's back.  :x He doesn't need any old cold weather to slow his brain down.  :wink: I got your back, Jon.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #359 on: November 11, 2014, 07:44:43 PM »
Yep... I see what you mean  :roll:
