Author Topic: Utah Belly Tank  (Read 159730 times)
Online manta22
Re: Utah Belly Tank
« Reply #180 on: June 05, 2012, 12:28:54 PM »
If you position those lights vertically on top of the dash so they reflect on the windshield, you'll have a "Heads-Up" display so you won't even have to take your eyes off the track.
Offline Captthundarr
  • In line
Re: Utah Belly Tank
« Reply #181 on: June 05, 2012, 12:32:58 PM »
If you attach the wires to the jewels there would be 0 delay in reacting to the signal. :-D
Online manta22
Re: Utah Belly Tank
« Reply #182 on: June 05, 2012, 12:39:44 PM »
That tends to cause the throttle to be jammed full open, though.  :-P
Re: Utah Belly Tank
« Reply #183 on: June 05, 2012, 01:54:39 PM »
OUCH! :-o
  • In line
Re: Utah Belly Tank
« Reply #184 on: June 05, 2012, 02:01:09 PM »
True Dat. We are to the point on Amy's car that the lights are getting put on during our down time so that all she has to look at is the big tach, big speedo (She'still working on her licensing) and the track.
Offline Jon
Re: Utah Belly Tank
« Reply #185 on: June 05, 2012, 02:18:40 PM »
Not sure if your running or interested in a knock sensor Wayno.
Detonation is the surest way to kill a motor IMHO and with a bit happening, the motor behind me with tanks and stuff between it and my ears I want something visual.
This is what I've bought for mine; http://www.viatrack.ca/
I haven't used it so cannot say if it is reliable or not, I was also given the schematics to build one by the guy I bought my dyno off.
jon
Underhouse Engineering
Re: Utah Belly Tank
« Reply #186 on: June 05, 2012, 03:27:50 PM »
Knock? Is that what your crew does on the canopy after you fell sleep waiting for the course to clear!?
And yes, I can fall asleep anywhere at will :wink:
Re: Utah Belly Tank
« Reply #187 on: June 05, 2012, 04:04:28 PM »
Thanx Jon. I'll keep that one in mind.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #188 on: June 05, 2012, 04:48:14 PM »
Been there...borderline narcoleptic....."Stew?...STEW!"....."huh?,....mmmmmmmmmmmmmm yeah, I'm with ya".....you're going flat out dawn til dusk, nowhere to sit down, you get in the car....quiet, kind of comfortable, you don't need to hold your head up...tick tick zzzzzzzzzzzzzzzzzzzzzz
Re: Utah Belly Tank
« Reply #189 on: June 05, 2012, 05:38:26 PM »
Don't hate me but I'm trying to get my air conditioner (cooler) built for the car by Speedweek.  8-) Wayno
Re: Utah Belly Tank
« Reply #190 on: June 05, 2012, 05:58:34 PM »
Hate you?.....like someone else said recently on the forum....." I've learned that while I have everything set up it's smart to make two"....
Can I have mine in red?
Re: Utah Belly Tank
« Reply #191 on: June 05, 2012, 07:09:02 PM »
Need AC here, pushing 100 today!
Re: Utah Belly Tank
« Reply #192 on: June 05, 2012, 07:15:33 PM »
quit whining, that's normal here. :-o
Re: Utah Belly Tank
« Reply #193 on: June 05, 2012, 07:21:23 PM »
Can be here as well, followed by 40 degree days!
Re: Utah Belly Tank
« Reply #194 on: June 14, 2012, 04:08:11 PM »
Elmo -- pm sent.
Past Member of the San Berdoo Roadsters -- "California's Most-Exclusive Roadster Club" -- Fifty-Seven Years of Leadership  Is Enough
