June 18, 2013, 04:50:19 PM *
CONTEST OVER!
Bill Reilly (Parkland Autosport) has donated TWO SETS of AN wrenches.
We're waiting for the winners to surface....
Details can be found in the forum here.
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19   Go Down
Author Topic: Utah Belly Tank  (Read 16215 times)
Elmo Rodge
« Reply #165 on: May 21, 2012, 06:52:03 AM »
Jon, when you say canopy, do you mean the hatch? Walrus, I was going to give Aircraft Windshield a call to freshen up on "care and feeding" of my screen. Wayno
Jon
« Reply #166 on: May 21, 2012, 03:28:22 PM »
Yes Wayno.
WOFTAM Racing, sponsored by Underhouse Engineering
Luck = Opportunity + Preparation
Elmo Rodge
« Reply #167 on: May 21, 2012, 03:59:25 PM »
OK Jon. There are 2 roll bars over my head and another forward of the hatch. Actually, the hatch opening is a few inches in front of the roll bar so I can grab it to exit.. Does that help?  grin Wayno
Vergil
« Reply #168 on: May 21, 2012, 09:42:24 PM »
Great build thread Wayno, was a pleasure visiting with you Sat at El Mirage. Took your advise and joined the forum, looks like it will be a great place to learn.
Vergil
Flathead Challenged
Elmo Rodge
« Reply #169 on: May 21, 2012, 09:53:08 PM »
It was great talking with you and Doug, Vergil. I'm really amazed that our paths hadn't crossed more solidly prior to this. You'll like it here. Wayno
Jon
« Reply #170 on: May 22, 2012, 01:05:28 AM »
Thanks Wayno
Cheers
jon
Elmo Rodge
« Reply #171 on: May 30, 2012, 03:39:39 PM »
I got the hatch built hinged latched and mostly fitted. I just got fully suited (again) to make sure I could exit the car in its' current configuration. I work on the premise that I know nothing and constantly check stuff. Anyway, my biggest concern has always been getting my helmet under the roll hoop to get out. Losing 15 pounds made it a snap. Oh, and the machine shop called to inform me that my block passed magnaflux and pressure test. Yippeee.  cool Wayno
Elmo Rodge
« Reply #172 on: June 04, 2012, 10:06:42 AM »
OK. Since I've made such an effort to isolate the cockpit from the engine compartment, the thought of running a pressurized oil line to run an oil pressure guage into said cockpit leaves me cold. Would I be better off with an electric guage? Wayno
Tman
« Reply #173 on: June 04, 2012, 11:21:20 AM »
Good question, hot oil not good. How about a guage in the back for tuning and a pressure sensor with an OH CRAP light up front for you? Pondering these things myself. cheers
www.compulsionrodandcustom.com
Hotrod, racing and performance parts
Jon
« Reply #174 on: June 04, 2012, 01:15:42 PM »
I'm only putting a set of idiot lights up front, for the motor will be red for oil pressure, yellow for coolant temp and "burn your eyes red" for knock, no lights = good.
Simple and you don't need to look.
Cheers
jon
grumm441
Location: Preston, Formally Australia's car theft capitol. Still a tidy town
HK 327
« Reply #175 on: June 05, 2012, 04:45:51 AM »
Just tie a rag around your leg under the gauge. oh , hang on, wrong car. rolleyes rolleyes
Put a gauge down the back somewhere so you can look at it when you are tuning it. Just a red light in the front for oil with a high pressure (more than 10 psi) switch, and a different color shift light, and a tacho. Doesn't matter where you put the tacho as you will not be able to see it
If you see a red light come on, switch the motor off and turn out, if you see the other color light, change gear.
G grin
I build it, Goggles tries his hardest to break it
Dr Goggles
« Reply #176 on: June 05, 2012, 05:34:08 AM »
G grin
He's couldn't be righterer. Theres a shipload going on at speed and there are two important pieces of info....."change gear" and "turn it off" are the two things you need to know.......my last run in our car demanded most of my available wits to keep it pointed in the right direction, that was likely due to the motor beating itself to death and the flywheel trying to escape but either way the lights didn't come on and I ran a good speed. Now, if I'd had gauges and been watching the oil pressure I definitely wouldn't have run that speed, but we would have had an intact motor. We've built a much better motor for under 4 grand.......Win!
Get idiot lights, the two seconds you spend focusing on a gauge could be lethal.
Elmo Rodge
« Reply #177 on: June 05, 2012, 06:23:42 AM »
Thanx guys. With any luck I'm smart enough for idiot lights.  tongue Wayno
Tman
« Reply #178 on: June 05, 2012, 11:08:09 AM »
Take pictures Wayno, the rest of us are copying you! cheers
Elmo Rodge
« Reply #179 on: June 05, 2012, 12:10:16 PM »
Goggles sed "Get idiot lights, the two seconds you spend focusing on a gauge could be lethal."
My attention span isn't nearly that long.  rolleyes Wayno
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19   Go Up
Google visited last this page June 14, 2013, 09:29:52 PM
