Author Topic: Utah Belly Tank  (Read 155659 times)
Re: Utah Belly Tank
« Reply #150 on: May 15, 2012, 12:04:19 PM »
I just climbed in and closed the hatch for the first time. It's really nice in there.  8-) I can't wait to drive it. Wayno
Admit it, you were making vroom vroom noises!
Good grief. I make vroom vroom noises when I'm cooking breakfast.  :roll: Wayno
Offline Jon
Re: Utah Belly Tank
« Reply #151 on: May 15, 2012, 02:18:56 PM »
Latch looks good Wayno
Does your pull cable run through the centre of the spring?
Cheers
jon
Underhouse Engineering
Re: Utah Belly Tank
« Reply #152 on: May 15, 2012, 02:34:40 PM »
Yes it does Jon. And it is stout enough that it should not accidentally deploy.   :cheers: Wayno
Re: Utah Belly Tank
« Reply #153 on: May 15, 2012, 05:32:40 PM »
 :cheers: :cheers: :cheers:
Miss LIBERTY,  changing T.K.I.  to noise, dust and RUST!!!
           tncsg.org     mrspowell.org
ELECTION  INTEGRITY  PROJECT
eip-ca.com  EIPAz.org  eipnv.
Offline 38flattie
Re: Utah Belly Tank
« Reply #154 on: May 15, 2012, 06:10:50 PM »
Looks goos Wayno! :cheers:
I'd kind of like to go to Van Dyne Engineering in  Huntington Beach, Friday morning, to talk with him about a water pump, then head to the lake.
Will this work for you?
http://youtu.be/89rVb497_4c
Re: Utah Belly Tank
« Reply #155 on: May 15, 2012, 06:18:11 PM »
You could leave him at my house.
Past Member of the San Berdoo Roadsters -- "California's Most-Exclusive Roadster Club" -- Fifty-Seven Years of Leadership  Is Enough
Re: Utah Belly Tank
« Reply #156 on: May 15, 2012, 06:33:55 PM »
That'll be fine. Wayno
Re: Utah Belly Tank
« Reply #157 on: May 15, 2012, 06:37:54 PM »
[/quote]
If you've never made those noises yr a stiff.
Offline Jon
Re: Utah Belly Tank
« Reply #158 on: May 16, 2012, 02:40:23 AM »
[/quote]
Never making those noises is as inexcusable as not trying on a tea cosy.
Re: Utah Belly Tank
« Reply #159 on: May 16, 2012, 10:03:15 PM »
Oddly enough, it's not as easy as it looks.  :-P Wayno
Re: Utah Belly Tank
« Reply #160 on: May 16, 2012, 10:04:57 PM »
I shouldn't have used the flash but you get the idea. Wayno
Offline salt27
Re: Utah Belly Tank
« Reply #161 on: May 16, 2012, 11:43:53 PM »
Wayno,
Thats one nice view and it will be even better in the morning after leaving impound. :cheers:
Re: Utah Belly Tank
« Reply #162 on: May 20, 2012, 11:00:05 PM »
Wayno, please post your experiences with the PTFE in use, how you clean it, any problems, etc.
Re: Utah Belly Tank
« Reply #163 on: May 21, 2012, 12:42:48 AM »
Quote from: Jon
Is that a snell 2005 Tea cosy?
Wazavudu Bellytank  Spirit of Sunshine Bellytank
Offline Jon
Re: Utah Belly Tank
« Reply #164 on: May 21, 2012, 05:38:27 AM »
Quote from: Jon
Grumm Grumm Grumm..........
Any good tech inspector should know that a tea cosy is NFI I mean SFI rated not Snell.
Sorry Wayno;
Is the canopy in front of the main rollbars?
So to get out you shift your but forward sit upright and the it's straight above you?
Thanks
jon
