Author Topic: Utah Belly Tank  (Read 162971 times)
Offline spbiknut
Re: Utah Belly Tank
« Reply #15 on: February 10, 2012, 04:51:13 PM »
Looks great! Was wondering where you got the belly tank body?  Also is there something some where that explains the use of a water tank over a radiator.  I understand that airflow is an issue in a belly tank, but I don't really understand the water tank and how it works.  Doesn't need to be said, but I'm new to LSR.
Thanks for any info.
-Troy
Re: Utah Belly Tank
« Reply #16 on: February 10, 2012, 04:57:35 PM »
Troy, I have the Tanks. And if someone on the Forum buys one, I shoot Jon and Nancy something.  :-D  The water tank is just that. A water tank. You just recirculate water through it during the run. Wayno
Re: Utah Belly Tank
« Reply #17 on: February 10, 2012, 05:13:15 PM »
-Troy
Troy, wayno SELLS those fine glass tanks.
« Last Edit: February 10, 2012, 06:16:12 PM by Tman »
Re: Utah Belly Tank
« Reply #18 on: February 10, 2012, 05:56:56 PM »
Hey Trent. Who's Tony? Is that a friend of Troy's?  :-D :cheers: :cheers: Wayno
Offline spbiknut
Re: Utah Belly Tank
« Reply #19 on: February 10, 2012, 06:09:43 PM »
That's ok...I've been called worse.  :-D  Thanks for the information.  Is there any kind of standard for the size of the water tank to the size of the engine...or is it just what size can fit the project?  I would think the larger the tank the better?
Thanks again,
-Troy
Re: Utah Belly Tank
« Reply #20 on: February 10, 2012, 06:16:50 PM »
I was dealing with a 5 year old driving hot wheels up my arm when I typed that! :lol:
Re: Utah Belly Tank
« Reply #21 on: February 10, 2012, 06:28:57 PM »
Was his name Tony? Sorry.  :roll:  Troy, there are formulas around for that. They used to be around here somewhere. I'll hafta look. Welcome to the Forum. Wayno
Re: Utah Belly Tank
« Reply #22 on: February 10, 2012, 09:33:55 PM »
Troy, your motor is the burner on your water tank... you don't want the water in your tank to exceed 210 degrees.... so depending on how much burner you have tells you how much water you might need to carry.  We have a 5+ gal tank in the lakester, made around 300 HP by my calculations and ran 5 miles just under 210 degrees...  we start with the water at salt temperature and this year ran a thermostat
Re: Utah Belly Tank
« Reply #23 on: February 10, 2012, 10:06:07 PM »
Troy there are lots of cars running water tanks of various sizes. There are also cars running radiators inside water tanks. The other thing that a lot of people do is make a larger opening in the water tank and add ice before a run. There are lots of ways to skin those cats!
Offline spbiknut
Re: Utah Belly Tank
« Reply #24 on: February 11, 2012, 08:14:37 AM »
Great information guys...thanks! More question to come I'm sure!
-Troy
Re: Utah Belly Tank
« Reply #25 on: February 13, 2012, 07:00:28 AM »
OK. Here's my chassis when I was painting it last June. Wayno
Re: Utah Belly Tank
« Reply #26 on: February 13, 2012, 07:02:33 AM »
The last one was in etching primer and this one is in paint. Wayno
Re: Utah Belly Tank
« Reply #27 on: February 13, 2012, 07:07:26 AM »
Now the fun part. You may have noticed the 36" diameter plywood disks mounted on the ends of the chassis to facilitate welding and painting. These were my poor mans rotisserie. This photo is of me strapped in and turned upside down to test belt loading. I figured if it was uncomfortable at this stage it was time to change it. As it turned out, no problem.  :cheers: Wayno
Re: Utah Belly Tank
« Reply #28 on: February 13, 2012, 07:12:10 AM »
One more. Wayno
Offline Captthundarr
  • In line
Re: Utah Belly Tank
« Reply #29 on: February 13, 2012, 08:05:36 AM »
Shoulda found a near by hill to give it the "true" rollover test. Looks real good Wayno :cheers:
