« Reply #120 on: May 06, 2012, 01:31:19 PM » |
My avatar shows Tok, a 100# Alaskan Malamute. He's the one who runs everything around here.
Captthundarr
Offline
In line
« Reply #121 on: May 06, 2012, 01:51:06 PM » |
Very coool Wayno, I want one
Live,Laugh, Love / Jack Scratch Racing /ECTA Amy Hartman-Driver, Frank Hartman-everthing else. C/GALT 137.65 Ohio Mile
Tman
« Reply #122 on: May 06, 2012, 03:57:26 PM » |
Chomp chomp chomp. Wayno
Who does the lexan for you? Or do you do it?
Jon
« Reply #123 on: May 06, 2012, 04:17:51 PM » |
Very nice Wayno
+1 on Tman's question, do you make the nose screen yourself?
Thanks jon
WOFTAM Racing, sponsored by Underhouse Engineering Luck = Opportunity + Preparation
« Reply #124 on: May 06, 2012, 04:24:27 PM » |
Marvelous windshield. The reflections from the light tubes are as straight as a string.
Good Job.
Offline
SCTA/BNI timer 1983 to 2004,Semi Retired,.
« Reply #125 on: May 06, 2012, 04:56:33 PM » |
Wayno, you going to the lakes, if so see you there.
Glen  South West, Utah
Elmo Rodge
« Reply #126 on: May 06, 2012, 09:56:25 PM » |
The windscreen is actually a glycol modified polyethylene terephthalate (PETG). I had it formed by Aircraft Windshield in Los Alamitos, California. It was on their suggestion that I use that material because it has the properties of Lexan with better optical clarity and formability. For the record, they were really good to work with and I'm happy as a clam.  Glenn, the light lines carry right on through on the body. You're right. They're very good. Glen, I'll be at El Mirage. I'm hitching a ride with Buddy and the Fladhead Cad. I have starting line duty Saturday morning and I'll be at the White Goose Bar. Wayno
38flattie
« Reply #127 on: May 06, 2012, 10:09:41 PM » |
See you next week!
Jon
« Reply #128 on: May 06, 2012, 10:28:41 PM » |
Thanks Wayno. Iv'e just will started emaling a guy in South Aus about making a canopy, I will see if he can do canopies in PETG.
Thanks jon
Elmo Rodge
« Reply #129 on: May 07, 2012, 08:15:02 AM » |
Jon, for the record I supplied them with a male mold for the screen. The mold has to go a couple inches beyond the edge that you want to end up with so you don't have wrinkles in that area. Also the process used is drape forming because it gives better optics than drawing the sheet into a mold. I used a mold that I got from Jack Kelly and carefully blocked it down to 320 grit. Oops. They proceeded to rough it up with 40 grit so the felt wouldn't slide around and bunch up. I had forgotten that part of the process.  Wayno
AHG
Offline
« Reply #130 on: May 07, 2012, 10:47:11 AM » |
Before cockpit construction is complete, you may consider engineering a small holder to house an "A" harmonica for use while waiting in line. Of course there is always the chance it may not pass technical inspection. Ha
Hopefully we have a date to Boogie again, at the Cook meet.
BR Drew Gatewood
"One hundred years from now my great great grandchildren will not remember my bank balance, the sort of house I lived in, or the kind of car I drove... but they will remember that I rode & raced a motorcycle."
Elmo Rodge
« Reply #131 on: May 07, 2012, 01:02:34 PM » |
Absolutely, Drew.  Wayno
Offline
« Reply #132 on: May 07, 2012, 01:47:42 PM » |
It's got a beer can holder, what more do you need.
« Reply #133 on: May 08, 2012, 12:31:12 AM » |
Wayno, did the SCTA approve the PETG or are you going to show up at tech and convince them it is OK?
Jon
« Reply #134 on: May 08, 2012, 12:37:35 AM » |
Thanks Wayno
Not sure if I will get something done here or over there.
First response from the guy I contacted didn't seem that exciting, I will hunt around here a bit more. I'm still a bit off needing it.
Thanks jon
