Author Topic: Second Wind: the 200mph Merkur  (Read 138831 times)
Re: Second Wind: the 200mph Merkur
« Reply #165 on: May 26, 2014, 04:33:55 PM »
Is this a good height for the lateral head restraint, 3.A.3?
« Reply #166 on: May 26, 2014, 07:35:45 PM »
around ear height, with you -20 fire suit on
looks about right
Offline 38flattie
« Reply #167 on: May 26, 2014, 07:50:47 PM »
Looking good, Mike! :cheers:
http://youtu.be/89rVb497_4c
« Reply #168 on: May 26, 2014, 07:51:31 PM »
Thank you, sir! (both of you!)   :cheers:
Offline Kiwi Paul
« Reply #169 on: May 27, 2014, 12:16:32 AM »
Mike..Do you need me to come and look? Sorry I didn`t get a chance to talk on Saturday.....
« Reply #170 on: May 27, 2014, 12:47:31 AM »
Sure, if you want to.  :-)
Give me a call at your convenience.
« Reply #171 on: May 27, 2014, 01:27:47 AM »
It looks very nice.
I love your attention to detail. :cheers:
« Reply #172 on: May 27, 2014, 01:38:36 AM »
It looks very nice.
High praise, sir! considering that my best looks like a two-year-old drawing on a wall with a crayon compared to what you're doing.
« Reply #173 on: May 27, 2014, 06:00:03 AM »
I beg to differ but thank you. :cheers:
« Reply #174 on: May 28, 2014, 03:43:48 PM »
Overkill?
Just under, as far as I can tell working alone, 4" wider than my helmet.
« Reply #175 on: May 28, 2014, 04:03:36 PM »
"Overkill?" ............ There's no such thing! Your cage is looking good.
« Reply #176 on: May 28, 2014, 07:04:57 PM »
Thanks, Pete.  It was supposed to be slightly tongue-in-cheek.
Ok, next problem.   :-D
Left-side belt mount, as original, seems well-placed:
Right-side, as original, ok for the seat Rick used (shown above), but I'm sure that Grib set the seat on top of it.
Not enough room for the original-style tube:
So, I propose using a piece of 1/4" x 3" similar to the cardboard, fit to the trans tunnel, welded solidly to the front and rear crossmembers as shown, and stitch-welded to the trans tunnel:
And then weld on the double-shear mount.
I think that this would provide more than sufficient strength.
Any thoughts or other ideas?
Offline Bob Drury
« Reply #177 on: May 28, 2014, 07:53:17 PM »
  Mike, it's looking good.  Just remember one caveat:  You want the tubing under the floor to be equal in strength to the cage over your head... people have exited out the bottom before.  Bob
Bob Drury
Offline salt27
« Reply #178 on: May 28, 2014, 08:58:06 PM »
Mike,
  When positioning your belt mounts make sure the belts don't rub on the seat.
I remember someone having an issue with that.
« Reply #179 on: May 28, 2014, 09:27:33 PM »
Thanks for the kind words and the advice, Bob.  The original longitudinal subframe was heavily reinforced by Byrnes & Co. and strongly ties into the Alston back-half, running directly under the seat:
Sorry for the angle.  Front is to the bottom (obviously).  Is that sufficient to keep me from falling out?  :lol:
Don, thanks for advice.  I expect that I'll have to trim the seat slightly to fit correctly.
