Author Topic: Second Wind: the 200mph Merkur  (Read 139450 times)
Re: Second Wind: the 200mph Merkur
« Reply #120 on: March 07, 2014, 09:29:43 PM »
A couple of weeks ago, I printed up the engine parts pictures that I posted here last month and took them to Aldridge Motorsport.  Denny was busy so I gave them and my phone number to the office manager (aka Mrs. Aldridge).
A week or so later, Denny called me and we set up an appointment to talk about the engine.  After an hour of questions and a few real answers, we agreed on what would be done and the price.
He has an engine in the dyno room to finish, another in the engine room to finish and then dyno, so in about two weeks I'll be taking him my parts and pieces. (Hurrah!)  Should take him about a month.  He only assembles engines that he wants to and does it on Tuesday and Thursday evenings with zero interruptions.  He encourages customers to come by and take pictures and post them on the web.
In the meantime, with enthusiasm renewed, it's back to work:
First problem is that the rudimentary engine mounts using Thunderbird Turbocoupe pieces that I threw together in April 2012 wouldn't work at all, the TC mounts intersected the Barnes dry sump pump.  So out came a generic small block Ford mount from Chassis Engineering (the street rod folks in Iowa, not the race car people) that had been sitting for several years along with some mid-80s 4-cylinder Mustang mounts that someone had made into solid mounts.  After a bunch of whacking and hacking:
It actually sits a little further forward than the picture seems to show.
Then out comes the old (stock) engine that made it easy to back out of the garage (uphill).
In goes the new mount (narrowed about 18"), shown in "full" mock-up.
The tube is notched in the lower rear to fit against the lower crossmember and it is snug against the frame rails.  The crank centerline is about an inch higher that the "stock" engine that was removed, but I'm going to have to modify steering mounts, and I'd like to keep it as high as possible.
Bonneville: I'm going to take Rick's advice and use the (low-horsepower  :-o ) turbo(s) that I have now, use the low-buck ECU setup (PiMP from Stinger Performance) that I now have, and make it to Speedweek if at all possible.
More later.
Offline Bob Drury
« Reply #121 on: March 07, 2014, 10:37:20 PM »
  Mike, that motor would look better in your living room than in the car!
        Ol' Bob up north............
Bob Drury
« Reply #122 on: March 07, 2014, 11:23:12 PM »
I'd be afraid of scarring the 1945 hardwood floor.   :-D
You over that crud you had?
Offline Richard 2
  • 2 Richards Racing
« Reply #123 on: March 07, 2014, 11:48:04 PM »
Mike, what flywheel and bolt pattern are you using?
4 cylinder Esslinger
Could of had a V8
« Reply #124 on: March 08, 2014, 12:13:42 AM »
R2:
The INTENT, not yet purchased, is a "5-liter" style (10.5") flywheel drilled for the 2.3 crank.  Trans will be a G-Force geared T5 with 26-spline input shaft.
« Reply #125 on: March 08, 2014, 10:06:34 AM »
I love those 4s! that is really coming along. I did not look back, what is the record you are chasing?
« Reply #126 on: March 08, 2014, 10:48:31 AM »
Thanks, Trent.  Record: F/BGC - 207.608
« Reply #127 on: March 08, 2014, 12:04:04 PM »
...  Trans will be a G-Force geared T5 with 26-spline input shaft.  Mike
Do you already have the transmission?  If not have you considered one of their 101's where you could have an almost endless number of gear ratios to pick from and they are also much stronger,
« Reply #128 on: March 08, 2014, 12:30:04 PM »
I do, Sum.  Picked it up really cheap.  Their website says, IIRC, that it's good for ~600 ft-lbs with drag radials on pavement, so it should be strong enough on the salt.
« Reply #129 on: March 08, 2014, 01:20:44 PM »
I agree that I also don't see a power problem with the HP levels the current engine is capable of, I was mainly thinking of the gearing options.  Lots of used fairly cheap gear sets out there for the 101 and the ones I've bought don't even look used,
« Reply #130 on: March 08, 2014, 01:33:15 PM »
I don't know enough to make any guesses as to alternate gear ratios.  It has: 2.94, 1.94, 1.34, 1.00
My inexperience says get it into 4th with minimal slip/sliding and go!   :mrgreen:
« Reply #131 on: March 08, 2014, 07:43:02 PM »
I believe only the last two merit any study.  They're surely okay for you to get going.  If you have a problem, you can adapt.  Thanx for the great hospitality a couple of weeks ago.  It's plain to me that you've got the know-how and the equipment for a serious endeavor.
Stan
« Reply #132 on: March 08, 2014, 09:01:43 PM »
The hospitality wasn't particularly good, but thank you, and you're sure welcome to come again next year.
Offline Bob Drury
« Reply #133 on: March 09, 2014, 01:33:26 AM »
  Hey Stan, how's your wife like your new hat?
  Mike, sorry about the thread hijack, still got the (Kansas?) crud............  Bob
Bob Drury
« Reply #134 on: March 09, 2014, 12:58:08 PM »
Damn thing weighs 14 pounds.  A little modification will help.  The thought is what really counts.  Thanx!
