Author Topic: electric (or whatever works) fuel shut-off for motorcycles  (Read 7354 times)
Offline ol38y
Re: electric (or whatever works) fuel shut-off for motorcycles
« Reply #15 on: January 23, 2012, 10:51:01 PM »
OK...Missed that but I still believe that the bikes I looked at only had a remote kill for the nitrous and not the main tank which was still only via the petcock.  I didn't look at it that close but I just don't remember seeing a remote mechanical for any gravity feed tanks.
You may not have seen them but they were there in fuel class.
Larry Cason
2010 BUB 1350 M-PG record
Offline saltwheels262
  • LTA 7/2013
« Reply #16 on: January 24, 2012, 07:09:08 AM »
Pingel Guzzler remote fuel switch ...
$200 worth.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline wfojohn
« Reply #17 on: January 24, 2012, 08:59:39 AM »
If you are currently using a Pingel Guzzler you can send it in to be converted to a shut off handle bar style and save a substantial amount, I was told yesterday that turn around time is only a few days.
Offline makr
  • I make my own rules
« Reply #18 on: January 25, 2012, 08:44:13 PM »
This is the Pingel petcock I have mounted to my RD400 tank. The release lever is mounted to the left side handle bar.
Ride fast, safety last.
https://speedofcheeseracing.com/
Offline Vinsky
« Reply #19 on: January 25, 2012, 11:25:54 PM »
How does this Pingle operate?
Offline 55chevr
« Reply #20 on: January 26, 2012, 05:17:43 AM »
To set on open, turn the butterfly on the valve body and push the handle bar thumb switch closed. The cable has a brass ferrule that drops into a recess on the valve body. This holds the spring loaded valve in the open position. When you thumb the switch it pulls and withdraws the cable and the valve springs to closed positon.
Offline davidd
« Reply #21 on: February 08, 2012, 09:56:07 PM »
I think it is the Yamaha that is causing confusion for Vinsky. This should help:
David
