Author Topic: tires  (Read 16279 times)
Offline Kix
  • 1997 GMC Saltnoma
Re: tires
« Reply #45 on: January 31, 2012, 09:31:57 PM »
I attached the Michelin Pilot Super Sport table of the tires I found applicable to LSR, but will send it to your email too Charles.
The wheel manufacturer is Marsh Racing Wheels...  nice guys.
http://www.rockcrawler-mrt.com/offroad%20wheels%2018%20inch.html
Kix
MODIFIED MID-PICKUP #4442
Bonneville Record:     219.35 mph
Maxton Mile Record:   193.14 mph
Ohio Mile Record:       192.80 mph
Offline Cajun Kid
Re: tires
« Reply #46 on: January 31, 2012, 10:13:48 PM »
Kix,
Thanks
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline Hooley
Re: tires
« Reply #47 on: February 01, 2012, 01:50:13 PM »
Guy's,
           Marsh Racing Wheels are what we have on the 974 Studebaker since we built it.  Good people to do business with.
                   Hooley
"Just Glad To Be Here"
Offline Cajun Kid
Re: tires
« Reply #48 on: February 02, 2012, 11:40:02 AM »
Hooley,
What rear tires did you use when you ran at Texas ?
Charles
OHIO
B/CGALT, C/CGALT
Offline Hooley
Re: tires
« Reply #49 on: February 07, 2012, 09:06:34 AM »
Charles,
             We put B.F.Goodrich drag radials on. They worked good but we were able to over power them.  I think for running on concrete I need a 4 link rear suspension instead of ladder bars. I will readjust the ladder bars for Ohio and add some weight. Maybe that will do it.
I am looking it a NASCAR tire too.
          All in the name of FUN.
                                                         Hooley
Offline Cajun Kid
Re: tires
« Reply #50 on: February 07, 2012, 01:44:46 PM »
Hooley,
If you have room to fit those wider Nascar rear slicks,, try the
Tire GoodYear brings to Talledega for the Left Front
I hear they work good.
I don't have room to use that wide a tire.
Charles
OHIO
B/CGALT, C/CGALT
Offline Fheckro
Re: tires
« Reply #51 on: February 26, 2012, 10:03:07 AM »
Has anyone tried BFG R1s ?
9479 Monza C/CGC
Current record Holder @ 180.000
Offline redcatch
Re: tires
« Reply #52 on: February 26, 2012, 10:51:53 AM »
Have run R-1 on a track day, a couple of times. They are a great cornering tire and turn in very nice. We were running 1/8 tow out that helped. Side walls I think are Stiff. Don't think its a good mile LSR type tire. I think the BFG drag radial would be better
Bob Cox
Redcatcher Motorsports
ECTA Record Holder
B/GALT
redcatch32@aol.com
Offline Cajun Kid
Re: tires
« Reply #53 on: February 26, 2012, 07:32:26 PM »
I already have rear  M/T Drag Radials so I have ordered Set of BFG Drag Radial II's (and are having them Heat Cycled)
this way I will KNOW which works best and which fits best.
The Heat Cycle process cost $15 per tire, but since it is under a controlled process and we don't allow burn outs, it seems the best choice to properly season a race tire,,,
Charles
OHIO
B/CGALT, C/CGALT
Offline redcatch
Re: tires
« Reply #54 on: February 27, 2012, 03:46:46 AM »
Thats the best $30.00 you will spend.
Bob Cox
ECTA Record Holder
B/GALT
redcatch32@aol.com
Offline Cajun Kid
Re: tires
« Reply #55 on: February 27, 2012, 04:29:51 PM »
Bob, I sure thought so myself...This way I know they have been properly heat cycled.
I ran my M/T's on the rear of the Vicky..(I did two little burnouts in my driveway before I loaded on the trialer,,, that was not enough,, Learned my lesson)
CV
OHIO
B/CGALT, C/CGALT
Offline redcatch
Re: tires
« Reply #56 on: February 28, 2012, 06:02:04 AM »
It took about 8 passes at Maxton to get the back tires right. They were green and would not scuff . On the last pass in OCT. we started getting good scuff patterns. I think my Home owners association would frown on me doing a burn out in front of the house. They all ready do.
We were running Goodyear Eagle DOT drag radials. THey should be just about right in April.
Bob Cox
ECTA Record Holder
B/GALT
redcatch32@aol.com
Offline Kix
  • 1997 GMC Saltnoma
Re: tires
« Reply #57 on: April 24, 2012, 06:09:37 PM »
Kix
Further on down the road... we have been looking for 18" - 20" wheels to run the Michelins on... and found these unbelievable beauties.
http://www.landracing.com/forum/index.php/topic,11174.0.html
There is also a new Goodyear Land Speed tire that is 10" wide and costs about the same or less than a drag radial.... two more options!
Kix
Re: tires
« Reply #58 on: April 24, 2012, 06:44:07 PM »
Kix
Size  Tire Code  Compound  MSRP  Rim Width  Overall Diam  Section Width  Tread Width  Weight  Min Inflation (psi)  Max Load (lbs)  Max Speed (MPH)
28.0x10.0-15  2270         Hard       $229         9.0      28.0      13.2      10.3     22.0      70.0     1700     300
Interesting!
