http://cgi.ebay.com/ebaymotors/Rear-Engine-Lakester-Dragster-Bonneville-land-speed-SCTA-/150738247095?pt=Race_Cars_Not_Street_Legal_&hash=item2318b31db7Rear Engine Lakester/Dragster for Bonneville, land speed, SCTAThis is a lakester/rear engine dragster my father had built to NHRA specs in 1989 and raced until 1996. It ran at Bonneville and El Mirage, as well as at a handful of drag strips around Northern California. It set records at Bonneville in the XXF/GL and XXF/FL classes at between 183-195 MPH with an Ardun and C4 transmission in it. In 1996 it ran at Bonneville with a SBC, it's last meet. At that race the roll cage was deemed to not meeting new SCTA rules regarding tube thickness and the car was retired. To make it elgible to race under SCTA rules again it would require a new roll cage.
The chassis is made of chrome moly tubing and was built by Frank Shonig Fabrication . The body was made by Jack Hagemann Jr. The car is designed to allow for either coil over suspension in the rear for land speed racing (169" wheel base) or to bolt up solid to the frame for drag racing (150" wheel base). The rear end used was a Halibrand Champ quick change with Strange axles - as you can see in the pictures the axles and axle tubes are included but the quick change is not. The front used a torsion bar suspension and a dropped front axle and Anglia spindles. Spindles are not included either.
What is included is everything you see in the picture of the parts on the shop floor. This includes Wilwood disc brakes for the rear, motor plates for a flathead/Ardun and SBC, scoop, various chassis tie rod pieces, driveline...... everything you see in that particular picture. I have also included pictures from when the car was being built and photos of the lakester on the salt as we raced it. THERE IS NO MOTOR, TRANSMISSION, WHEELS, TIRES, QUICK CHANGE, HEADERS, RADIATORS, OR ANYTHING ELSE INCLUDED IN THIS AUCTION THAT CANNOT BE SEEN IN THE PHOTO OF THE MISC. PARTS ON THE SHOP FLOOR OR ON THE VEHICLE AS IT SITS ON THE GROUND WITH NO ENGINE OR WHEELS. The first 8 photos are all you get. Period. All other pictures are included for you to see what the car looks like complete.
Vehicle weight when complete, with driver, was approximately 1800 lbs. It made approx. 2 dozen + runs at the drags in the 10 second E.T. range with a naturally aspirated Ardun on gas.
The workmanship involved in this car is absolutely beautiful. As mentioned it would take a new roll cage built to SCTA specs to make it eligible to run again. Or use the front half as the foundation for your Rear Engine Modified Roadster (RMR) project.
I have this vehicle for sale locally and reserve the right to end the auction early if it sells. Local pick-up only.
