Author Topic: 93 Twin Turbo BBC A/BGT Corvette  (Read 27203 times)
Offline redhotracing
Re: 93 Twin Turbo BBC A/BGT Corvette
« Reply #15 on: June 12, 2012, 10:58:55 AM »
Specs on the forced induction setup?
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline robfrey
    • carbinitelsr
« Reply #16 on: June 16, 2012, 04:33:25 PM »
Twin Holset HT60 which have very similar mapping to Garrett GT4708 (81mm), Precision Turbo ice water intercooler, with a very, very large reservoir tank (partially to act as ballast). Turbos are mounted where the passenger would sit in such a way that a catastrophic failure would not injure the driver. Actually the turbo location really worked out nice and everything is easily serviceable. As a result, the engine compartment is very uncluttered.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline robfrey
    • carbinitelsr
« Reply #17 on: June 28, 2012, 12:18:58 AM »
This car has been sold.
It should be in the salt this year.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline maguromic
« Reply #18 on: June 28, 2012, 12:22:37 AM »
Somebody got a great deal.  Tony
Offline robfrey
    • carbinitelsr
« Reply #19 on: June 30, 2012, 07:30:43 AM »
Tony, you are correct. Wait till you guys see this thing on the salt. This car is even nicer than I remember it. It has been almost 4 years since i have seen the car in person. We intend to be at speed week with it this year.
I may start a build thread about this car but I need to okay it with the new owners.
Even though it will detract from our liner effort, I think the added experience will help with our liner effort.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline bvillercr
« Reply #20 on: June 30, 2012, 12:28:21 PM »
246.15 mph and he will be wearing a red hat. :cheers:
Offline Kiwi Paul
« Reply #21 on: June 30, 2012, 11:30:46 PM »
Rob, I hope you have run through all the updates in the 2012 Rule Book and made sure they are in place. I recall looking at one of the cockpit photos and didn`t see a throttle pedal loop. I hope to see the car in person, and trust you have done your homework.....Knowing how thorough you have been in the Streamliner design, I`m sure you have checked this stuff.....
Offline robfrey
    • carbinitelsr
« Reply #22 on: July 01, 2012, 09:40:34 PM »
Does a throttle loop help anything if you have a cable actuated throttle?
We know the seat needs change, have you seen anything else we might have a problem?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
« Reply #23 on: July 02, 2012, 12:35:46 AM »
Does on both of ours....  if the return springs broke they want you to be able to close it....
Offline robfrey
    • carbinitelsr
« Reply #24 on: July 02, 2012, 11:02:53 AM »
Yeah, but is hard to "push" a throttle cable. I would think that a third throttle spring would be more effective in the event of throttle stick. We do have a throttle stop under the pedal to keep from going over center or stressing the throttle shaft under wfo condition.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Dynoroom
« Reply #25 on: July 02, 2012, 11:44:24 AM »
We get this question a lot in tech with new cars. We understand the reason for the question.  But.........       :?
The Answer......... Toe strap, throttle returns, or hoops,............ are required.    :-o
If you'd like to change the rule you can get a rule change form on the SCTA web site.      :evil:
« Reply #26 on: July 02, 2012, 12:25:56 PM »
If you use a more substantial type cable such as Morse or similar you can close the throttle with a toe loop. The extra safety may be worth it. The chance of a broken spring or bracket is a good reason to install the multiple springs in multiple locations on separate brackets.
Offline Captthundarr
  • In line
« Reply #27 on: July 02, 2012, 01:05:06 PM »
Any of the above or all of the above????
  • In line
« Reply #28 on: July 02, 2012, 01:06:02 PM »
What type of cables are you using?
Offline Dynoroom
« Reply #29 on: July 02, 2012, 01:24:58 PM »
Any.
I added the other names as examples of what they've been called by different people/groups. One in the same to me.
