Author Topic: 650cc A-BG build TDR  (Read 17513 times)
Re: 650cc A-BG build TDR
« Reply #15 on: December 13, 2012, 06:52:50 PM »
That is some sexy fab work.  :cheers:
« Reply #16 on: December 13, 2012, 11:51:38 PM »
It will not be too hard to change motors with that setup.  All of that trianglation looks good.
Offline Koncretekid
« Reply #17 on: December 29, 2012, 06:54:14 AM »
Your tubing, 1.25" x .120" vs. 1.00" x .060" (my tubing) is approximately 2.3 x stronger in compression and tension, and 2.7 x stronger in bending resistance.  My failures were fatigue related to the rear tail section bobbing up and down which induced cyclical loading combined with a bending stress caused by attachments.  After the first tube failed, I apparently continued to run which accentuated the stresses applied to the rest of the structure.  Use a nice high gloss paint and inspect the frame regularly for cracks. I've basically come to the conclusion that no one could have predicted the failure of my first tube, the vertical unbraced strut that supported the rear section.  All designers eventually run into situations leading to failures that weren't predicted.  That's when you add another tube or make the existing one stronger.
Offline Hellcat Customs
Re: Re: 650cc A-BG build TDR
« Reply #18 on: January 07, 2013, 12:38:15 PM »
I really like the chassis work... neat concept nice execution.... You are making a support bracket for the turbo as well yeah? I've never had any luck just having it hang from the header...then again mine have never been 4 cyl headers either...maybe the extra primaries help carry the load.
« Reply #19 on: January 10, 2013, 12:17:04 AM »
Awesome! Personally I've had manifold failures because I only supported the turbo on one side....granted we are into turbo Harleys and have horrible vibrating tractor motors... So it may not be a problem. I always end up over building stuff.
Offline 55chevr
« Reply #20 on: January 10, 2013, 06:38:38 AM »
Harley V twins are tough on turbo exhaust manifolds.   I have tried a couple of different ways of supporting them.  What has worked the best has been supporting the turbo from 2 points to the engine, not the frame.
« Reply #21 on: January 10, 2013, 09:50:57 AM »
Found the same out the hard way... the other weak link is the exhaust flanges/retainers... Found out that welding the flanges to the header made it so the header can't rock around and wiggle so much which really helped a great deal.
Offline V4F STR 60
    • Montana Dodge Boys Fast Four Special
« Reply #22 on: January 13, 2013, 06:54:32 PM »
You really need to spend less time in the shop and a little bit more plowing my driveway   :cheers:
1928 Dodge Brothers Vintage Flathead Four Cylinder Roadster & Lakester
Landspeed Records
Bonneville
2009 V4F/STR 115.681
2009 V4F/GR 116.439
2009 V4F/FR 117.597
2010 V4F/BSTR 127.352
2012 V4F/BFMR 130.843
2013 V4F/BGMR 142.956
2013 V4F/BFMR 143.254
2013 V4F/BGR 138.395
2013 V4F/BFR 138.984
El Mirage
2016 V4F/BGMR 140.961
www.facebook.com/MontanaDodgeBoys
www.fastfourspecial.com
