Author Topic: Inline-four crankshaft  (Read 478644 times)
Offline Jack Gifford
Re: Inline-four crankshaft
« Reply #495 on: October 02, 2019, 11:50:44 PM »
Yeah, I'm certainly considering the Loring July event. I believe I'm in pretty good shape for the inspection.
I hope to get my fire systems changed from foam to FE-36 this winter- I hate the thought of trying to exit the cramped cockpit if it were full of slippery foam.
Late note: Wow- don't know how I missed it, but rules (both SCTA & LTA) REQUIRE(!!) a Halon-like agent in the driver's compartment. I'm glad I was planning to change it this winter anyway. Bottle is on its way to FireFox to be filled with Halotron-1.
« Last Edit: November 13, 2019, 11:54:37 PM by Jack Gifford »
M/T Pontiac hemi guru
« Reply #496 on: January 08, 2020, 01:35:43 AM »
Just received the bottle back from FireFox, filled with Halotron-1. Wow- almost two months  turnaround. :-( Glad I wasn't in a hurry! At least the price was decent- under $300.
That's for the cockpit system. Not sure whether I'll eventually change the engine system also.
« Reply #497 on: January 08, 2020, 11:28:56 PM »
A question from a dumb bike guy...  Will releasing halon in a closed environment like a cockpit suffocate the driver?
Offline Saltfever
« Reply #498 on: January 09, 2020, 12:10:01 AM »
Yes. Some of the hospital recover times have been due to the effects of Halon. But consider the alternative . . .
« Reply #499 on: January 09, 2020, 12:44:39 AM »
Yet airliners use exclusively Halon. The only legal production of Halon is for the airlines.
Offline Saltfever
« Reply #500 on: January 09, 2020, 01:42:37 AM »
When the Halon ban was introduced airlines worldwide squawked and lobbied against the ban saying there was no equivalent substitute. They were right . . . and granted a "temporary" reprieve. Research is on-going to find or invent a non-ozone producing substance with the efficacy of Halon. Don't hold your breath . . . yes, pun intended.
« Reply #501 on: January 13, 2020, 12:45:58 AM »
I would really like to use my fixed-up '59 GMC pickup to haul the lakester, but would hate to scratch the pristine paint with fuel jugs, tools, etc. So I just finished building a "free standing bedliner" of 1/2" plywood, which will mount on four existing bed floor bolts with 1" clearance underneath and all around it. It's on the small side but the truck already has a weatherproof storage box across the front 18" of the bed, so I hope there will be room for everything. I'm now working on a fitted heavy-tarp cover for the bedliner.
Offline salt27
« Reply #502 on: January 13, 2020, 12:53:34 AM »
Jack, Does that 59 GMC have a Pontiac V8 in it by chance?
Just a guess, Don   :wink:
« Reply #503 on: January 13, 2020, 07:40:37 PM »
If you just Google "Halon" the industry are very busy with the line "Halon is completely safe and non-toxic" which reminds of several other valuable industrial chemicals over the years... I did find this... Airline flight staff who have been exposed have lingering  pulmonary inflammation issues years after the event.
https://oem.bmj.com/content/61/8/712
« Reply #504 on: January 14, 2020, 02:04:56 AM »
Don- Yes, the GMC left the factory with a 336 (actually 337) c.i. Pontiac V8 (a small-bore version of the car's 389). But when I bought the truck someone had swapped in (a better term would be "hacked") a late Pontiac 350. So I built and installed a modified '58 Pontiac engine- which is outwardly identical to the 336 (well, if you ignore the SD Tri-Power intake!). But it's very modern inside- 382 c.i., 9.1:1 C.R., re-designed combustion chambers, hydraulic roller cam, crank trigger ignition, long branch manifolds with 2.5" stainless duals with hand-built copies of the rare GTO option VOE mufflers (switch on the dash makes them straight-through), etc.
« Last Edit: January 14, 2020, 02:08:26 AM by Jack Gifford »
Offline salt27
« Reply #505 on: January 14, 2020, 03:45:14 AM »
Jack, In my late teens I worked as a mechanic at a GMC dealership and one of our customers had a 59 pickup with the Pontiac engine.
It didn't take too much guess work to figure that's what you would be driving.   :cheers:
That is a very nice truck.
« Reply #506 on: January 19, 2020, 01:43:39 AM »
Fitted tarp is done.
« Reply #507 on: May 03, 2020, 12:07:49 AM »
The liner actually fits in the bed!
Entries submitted for both 2020 LTA events. Yes, I'm anxious to get on the track!
« Last Edit: May 03, 2020, 12:11:25 AM by Jack Gifford »
« Reply #508 on: June 08, 2020, 01:28:08 AM »
I'm bummed. LTA has cancelled the July event. Just as I was congratulating myself on being on-schedule with tasks on the lakester. :x
Oh well... I'm sure I'll come up with more "improvements" to keep me busy until the Harvest Event.
« Reply #509 on: June 08, 2020, 01:09:52 PM »
Hey Jack, we worked on ours for 34 years and never finished it... LSR cars are rarely completed...  :?
doesn't stop ya from racing in current condition as long as they pass safety.  :cheers:
