Author Topic: Inline-four crankshaft  (Read 478137 times)
Offline jacksoni
Re: Inline-four crankshaft
« Reply #450 on: November 06, 2018, 08:08:48 AM »
Are your cam bores still straight? I've had some trouble with head warping (when I first got the head it was not straight and then I got it hot once and did further damage) and the cam tunnels were then out as well as deck not being flat.
« Last Edit: November 06, 2018, 08:22:26 AM by jacksoni »
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline Jack Gifford
« Reply #451 on: November 07, 2018, 12:56:12 AM »
Yes, cam bores are aligned okay. Maybe I shouldn't have said the head "lifted", since the top surface of the head was still flat. The distortion was all at the head's deck surface- as if the center of the head got "crushed" a little. [These heads were made in 1961- cast aluminum alloys weren't as advanced as today's are].
M/T Pontiac hemi guru
« Reply #452 on: November 23, 2018, 10:44:41 PM »
Engine is back together. Too wintry now to wheel it outside for more test running.
Finally got around to some research that I had postponed. Put together a test sample to look at possible loss of fastener torque after heat cycles of the magnesium crank filler segments. Identical fasteners and material thicknesses as the actual crank, and included a steel-to-steel "control sample". Ran it through six cycles of 15 minutes at 230 degrees F, then cool. No real surprise in results- steel-to-steel lost 25% torque, magnesium-on-steel lost an average of 33%. That's still within the safety margin of the design, but not by a lot. Next time the pan is off I'll re-torque those fasteners.
« Reply #453 on: January 16, 2019, 11:04:44 PM »
Idle minds breed trouble?... :-o
I've rigged up a "static dyno" to enable loading the engine somewhat during the next test-running. Removed all weights (even the attaching bolts) from the full-centrifugal CrowerGlide- I guessed full lockup will now be up around 6,000 RPM (Crower guesses about 5,500). Made up a rugged 2' long torque arm on the QC box's output shaft, anchored to an S-type load cell, which is in turn anchored to the engine mounting (via an old-fashioned 550 lb. game scale, for quick visual reference). Logging ten data points per second should provide some useful data, despite being limited to 2-3 seconds bursts to not cook the clutch too badly. The arm also has a shock absorber to dampen its movement.
Don't be too alarmed- there's plenty of over-sizing of fasteners and other pieces. And a stout "gate" is provided to contain the arm in any event.
Offline salt27
« Reply #454 on: January 16, 2019, 11:49:17 PM »
Will there be a video?
Be safe Jack.   :-o
« Reply #455 on: January 25, 2019, 01:03:11 AM »
Finished the torque monitoring stuff. The instrument amplifier I bought was crammed onto a 1" square board, which I had to package in a plastic box with terminal strips. Just soldering 7 wires onto that tiny board was a challenge for my shaky hands. Wired it into the engine's harness, spent some time setting the gain and offset, and set up the logger channel for torque readings (thanks for the loan of  the logger, Stainless!). Static loads show it's pretty close to the game scale readings from 0 - 440 ft.lb.- I'll tabulate more increments tomorrow to get percentage-difference numbers.
[No, I don't do videos...]
« Last Edit: January 25, 2019, 01:29:26 AM by Jack Gifford »
« Reply #456 on: January 25, 2019, 10:22:15 AM »
What instrument amplifier did you use, Jack?
« Reply #457 on: January 25, 2019, 11:24:56 PM »
In-amp is an AD620, on a board with gain & offset resistors, miscellaneous filters, etc.
This plot (done statically) shows some non-linearity, but I don't know whether the load cell or the spring-type game scale is more to blame. In any case, it will [hopefully] provide a little useful data.
« Reply #458 on: April 06, 2019, 11:53:16 PM »
I can't find a twiddling-thumbs moticon...
Just waiting for mild weather- for another test-run (and bearing inspection, etc.), then start cramming it into the lakester.
Offline Koncretekid
« Reply #459 on: April 08, 2019, 10:59:05 PM »
So the torque arm and the scale are well fastened, but don't forget to anchor the motor down.  500 ft. lbs. could probably turn the whole car over.
« Reply #460 on: April 27, 2019, 02:03:56 AM »
Nice weather yesterday. Got a friend to play fireman and monitor air/fuel ratios on the laptop. Didn't hurt anything or anybody!
Logging didn't work (RFI from magneto?). My plan for higher speed lockup of the CrowerGlide (5,000 RPM or so) was all wet- I ignored the fact that centrifugal force increases as the square of angular velocity. Even with no clutch weights, full throttle for 2-3 seconds only got a little over 4,000 RPM, with the analog scale showing about 300 ft.lb. of torque.
Bad stuff: no log of precise data, barely made any boost pressure, and didn't get to where it's intended to make power (6,000-9,000 RPM).
Good stuff: air/fuel was around 5:1 as hoped (still conservative but better than the 4:1 at the dyno shop), engine was stable and smooth while under load at full throttle, and no indication of clutch destruction (other than cool-down noises afterward!).
Rationalizations: if scaled up from 182 c.i. to 454 c.i. these numbers would be 750 ft.lb. and 600 HP @ 4,000 RPM.
I believe it's at least capable of propelling the car, so I guess it's time to look at squeezing it into the lakester.
« Reply #461 on: April 27, 2019, 06:39:10 AM »
VERY likely.    I have had to fabricate a "magneto shield" on some dyno installations to be able to prevent interference.
A length of large diameter aluminum tubing with a grounding wire usually works.  Think mag suppression for a P-51.    NO mag suppression, NO RADIO . . . . SO . . . . .
Some P-51's also used grounded brass tubes to "encase" the spark plug wires . . . . .
I have heard that in a pinch, Reynolds Wrap (aluminum foil) can be your friend . . . . . . . .
Glad to see your project up and running again.
M
« Reply #462 on: May 16, 2019, 12:43:10 AM »
Baby steps...........
« Reply #463 on: May 16, 2019, 12:45:36 AM »
Offline RidgeRunner
« Reply #464 on: May 16, 2019, 08:11:20 AM »
Jack,
     Looking great!
     Any plans for some shake down passes at Loring or are they too far off yet?
     I like the spreader bar concept on your lifting device, great new ideas for a new one for us when I get 'round to it :cheers:
