Rich,
Bottom of page 64 in your 2011 rulebook.
The addition of Foreign cars in the Classic Category is a test only. Note the part where the foreign cars are not allowed to compete for El Mirage points. The F engine class limit includes every displacement from K(0 cid)up to F(183.9 cid). The new rule for 2011, bottom of page 15 in your 2011 rulebook,allows engines with a smaller cid to run against larger engines if the break is not available to your class.
From 2011 rule book with updated records:
ENGINE CLASS BREAK
Omega Engines using a thermodynamic cycle other than Otto
Cubic Inch Liter Equiv.
AA 501.00 cid and over 8.210 liters and over
A 440.00 to 500.99 cid 7.210 to 8.209 L
B 373.00 to 439.99 cid 6.112 to 7.209 L
C 306.00 to 372.99 cid 5.015 to 6.111 L
D 261.00 to 305.99 cid 4.277 to 5.014 L
E 184.00 to 260.99 cid 3.015 to 4.276 L
F 123.00 to 183.99 cid 2.016 to 3.014 L
G 93.00 to 122.99 cid 1.524 to 2.015 L
H 62.00 to 92.99 cid 1 .016 to 1.523 L
I 46.00 to 61.99 cid 0 .754 to 1.015 L
J 31.00 to 45.99 cid 0 .508 to 0.753 L
K up to 30.99 cid 0 .507 L and under
In classes where not all engine breaks are available, the smallest displacement class allowed is open to all engine displacements that fall within it and below it.
SECTION 6
BONNEVILLE NATIONAL CAR RECORDS
Classes with no listed record are considered as open.
6.C Classic Category
Classic Blown Fuel Altered - /CBFALT
F The Hudson Boys S. Carlson 08/11 129.641
Classic Unblown Fuel Altered - /CFALT
F Cohn Jucewic Monza B. Jucewic 08/11 165.224
Classic Blown Gas Altered - /CBGALT
F The Hudson Boys S. Carlson 08/11 123.782
Classic Unblown Gas Altered - /CGALT
F Cohn Jucewic Monza B. Jucewic 08/11 182.357
Classic Blown Gas Coupe - /CBGC
F Clean Air Corvair T. Keosababian 08/74 173.090
Classic Unblown Gas Coupe - /CGC
F Cohn Jucewic Monza B. Jucewic 08/11 174.922
Classic Production - /CPRO
F OPEN
Classic Production Supercharged - /CPS
F Not Available
SECTION 10
EL MIRAGE CAR RECORDS
Classes without a listed record have an established minimum record speed.
Established minimum record speeds are in the current revision of the El Mirage Procedures that are available at the SCTA trailer or at
www.scta-bni.org10.C Classic Category
Classic Blown Fuel Altered Coupe - /CBFALT
F Minimum
Classic Unblown Fuel Altered Coupe - /CFALT
F Minimum
Classic Blown Gas Altered Coupe - /CBGALT
F Minimum
Classic Unblown Gas Altered Coupe - /CGALT
F Minimum
F Minimum
F Minimum
Classic Production Coupe & Sedan - /CPRO
F Minimum
F Not Available
