Author Topic: Ford Falcon Race Catergory  (Read 2861 times)
Offline craigibc
« on: November 21, 2011, 10:54:31 PM »
We are trying to figure out which class our car will fit into in the SCTA class system. This will give me an idea on the horsepower numbers our small block will need to produce.
Looking into the rule book this is what I am up with: D/BGC
Car specs:
Stock-bodied 1962 Ford Falcon
Ford explorer 8.8 rear end
Ford 289/C4 with aftermarket EFI (Megasquirt) and a Paxton Supercharger.
Craig
Offline RichFox
Re: Ford Falcon Race Catergory
« Reply #1 on: November 21, 2011, 11:41:27 PM »
Sounds right
Offline Kiwi Paul
« Reply #2 on: November 22, 2011, 01:27:37 AM »
If you had a conventional (mechanical) injector and no electronics,it would be a Classic Gas Coupe for sure, but the Megasquirt and accompanying stuff moves it over into Gas Coupe....or Altered if you change the front Aero or engine setback, and/or run it on anything other than event/spec Gasoline.....
Offline NathanStewart
« Reply #3 on: November 22, 2011, 10:37:09 AM »
just an fyi... that 8.8 won't fly if it still has c-clips.
El Mirage 200 MPH Club Member
Offline DallasV
« Reply #4 on: November 22, 2011, 11:27:14 AM »
The difference is 209 MPH vs 276 MPH.
« Last Edit: November 22, 2011, 11:29:05 AM by DallasV »
