Bill,
If I might pipe in again, and save you some work.
Clutches and Flywheels seldom fail these days. Especially on the salt.
I would suggest that a 9 inch clutch will handle the power you will make (and have some engine reliability).
I am currently turning a 2.3 to 9500RPM and not having difficulty with alum flywheel, single 9" clutch disc and a lighter weight pressure plate. (alum, with steel insert). Because of the higher engine speed, I am looking at a twin disc clutch, but for the next couple of seasons I don't think it is really necessary.
Do, look at how much wear you get with lots of chassis dyno testing. I had a clutch failure in 98 when we had about 6 trips to the chassis dyno and some track testing with the bonneville gearing. (lesson learned).
I am a proponent of OVER engineering/designing a LSR car, but don't and wont use much more than I have now. Pay attn to stainless. The additional 1/4" plate or 1/4" wall tube around the fuel line where it passes the plane of the flywheel is like everything, the minimum requirement. For the most part, weight is your friend.
My old Merkur was 4200 lbs ready to run on the salt, and it still spun the tires if boost came up too fast.
Good luck with your buld .
LONG LIVE THE PINTO MOTOR
