The Saga continues
Here is one of the exhaust ports cleaned up with the adapter flange mounted. This will probably be the only one I will finish off so Jack can test it. There are two pics.
Here is the port with the tubing held in place, another two pics. Now I have to weld it in place, Rich is going to machine a flange to weld on the top. Again two pics. ( I was originally considering doing something like this on the intake side, coming in under the rocker arms straight towards the valve, tried the pictured way instead. I became a little timid, for some reason, about the water jackets. )
Now I need to go, Happy Thanksgiving.
