To give you some idea what might be gained at the lower lifts, here's some numbers for the Midget -
.100 44.0
.200 87.6
.300 111.7
.4500 124.1
.500 125.6
Keep in mind that this is a 5 port head with a 1.48 valve and shared intakes, and I'm only feeding 1 liter. At .100, .200 and .300, the numbers between your head and mine are virtually identical, but for a one liter engine, it's considered pretty good flow. If the Stude is punched out to 5 liters, that's 2.5 liters per side, well, you can see where the bottleneck is on the Stude - it's around the valve seat, the bowl, and quite likely shrouded around the valve in the combustion chamber.
ZD, can you post up a pic of the combustion chamber side of this head?
This is a very fun project - I hope it eventually leads to a working set of heads.
