All my bike liner chute releases are electric over air on a bimba air ram. One side of the electric goes to the 12v pos and the neg lead goes to a button on my handlebars. At about the bulkhead, the neg lead ?t?s? up to my tip over switch mounted above the roll center on the bulkhead. My tip over switch is an elaborate exotic electric contact switch? ok it?s a set of Chevrolet ignition points. I made a eccentric cam that is attached to a fishing lure lead weight kinda pendulum thingy that keeps the contacts open, and when the bike leans over more than 45dg the pendulum swings, the contacts close completing the circuit, and the chute pops out the back. Worked perfect on my 217mph crash. Whatever you design they will have you demonstrate its function at tech.
Kent
Ps? oh yeh definitely have it kill the fuel pump AND motor. You can do that easy with a bosch relay
