If someone wants to post info. on their vehicle I would like to run it through my current simple estimator.
Low HP cars or motorcycles that you think are not noticeably spinning the tires at full throttle in any gear only.
High HP cars that require pedaling are probably almost impossible to attempt an estimate in a simple manner.
Need:
- engine torque or hp as a function of rpm (dyno chart preferred)
- gearing and trans. ratios
- rolling radius of driver tire(s)
- timing slip info - or point to online records I can look it up.
- push vehicle detach point and speed, rpm at that speed.
