Author Topic: Motorcycle frame design question  (Read 12415 times)
Offline peterdallan
« on: August 13, 2011, 11:38:35 AM »
Hi,
    Just beginning to sketch out a couple of designs for my frame for next year.
I will be going in the 650cc Pushrod Fuel/Gas classes, Special Construction frame.
Question, can I have a frame where the top tube is the gas tank and the downtube is the oil tank?
thanks
Peter
Offline Dakin Engineering
Re: Motorcycle frame design question
« Reply #1 on: August 13, 2011, 02:03:25 PM »
For gas class, the tank must be sealed.
They like to visually verify the tank is empty before filling and sealing.
Sam
#6062
Turbo Sportsters since '97
Offline ol38y
« Reply #2 on: August 13, 2011, 02:10:41 PM »
I don't know of any compliance reason you can't. But, you'll severly limit your capacitys , especially gas. JMO
Larry Cason
2010 BUB 1350 M-PG record
Offline peterdallan
« Reply #3 on: August 13, 2011, 02:16:35 PM »
Thanks Sam,
                  Alternative is to fit a couple of tube tanks alongside the top frame rail, however wouldn't I come up with the same problem regarding checking the tank is empty as they would be quite long and thin?
JMO, what would be an ideal capacity for a run in your opinion? I was planning to have a much larger diameter top tube than normal if I went this route.
Cheers
Peter
« Last Edit: August 13, 2011, 02:35:35 PM by peterdallan »
Offline ol38y
« Reply #4 on: August 13, 2011, 02:23:49 PM »
IMO 1 to 1.5 gals for gas with the twin alum. tubes. Then you'd have the top rail and the down tube for oil. But, JMO
Larry Cason
Offline Vinsky
« Reply #5 on: August 13, 2011, 02:41:43 PM »
You said fuel/gas class.  If you are running Alky, you need a much larger tank than for gas.
Offline 55chevr
« Reply #6 on: August 13, 2011, 03:11:07 PM »
I race a 1000cc pushrod bike at Bonneville and it uses more then half a gallon during the run ... it is 3 miles wide open ... youop are gonna need a really big top rail ... also your fuel weight drops as you consume the fuel during the run.   A lot of special construction bikes use a fabricated fuel tank that fits conveniently into the frame design.
Offline ol38y
« Reply #7 on: August 13, 2011, 03:24:19 PM »
Yup, I glossed right over that. If you're running fuel you'll probably want 3 gals available.
Larry Cason
Offline peterdallan
« Reply #8 on: August 13, 2011, 03:30:24 PM »
Ok all good info, thanks, will help with the frame design choice.
Peter
Offline RidgeRunner
« Reply #9 on: August 13, 2011, 03:45:21 PM »
Gravity feed for carburetor is one thing.  Any type of FI with  a return to tank could bring on aeration where the return dumps into the tank in which case baffles and/or larger capacity might be need to be considered.
Offline ol38y
« Reply #10 on: August 13, 2011, 03:54:05 PM »
Nuther good point. Also, when determining fuel line size, bigger is better.. :cheers:
Larry Cason
Offline bak189
« Reply #11 on: August 13, 2011, 07:48:58 PM »
What engine are you using????.......1.5 gallons should be enough if you are using gasoline for fuel........
We ran a 750c.c Triumph with a top tube frame tank on gas (record still stands) with no problem.......
To show the tank is empty ....just disconnect the fuel line and show the man the tank is empty..Simple..
Question authority.....always
« Reply #12 on: August 14, 2011, 01:18:14 AM »
My experience with oil-in-frame is they are difficult to thoroughly clean out if the oil is contaminated, for example, by an engine failure.
Offline peterdallan
« Reply #13 on: August 14, 2011, 04:31:05 AM »
We are using a 1960 Triumph 6T engine as the basis for our build.
Peter
Offline bak189
« Reply #14 on: August 14, 2011, 03:14:48 PM »
With the 6T Tri. engine on gas (petrol to you) about 1 gal. should be enough......Our frame tank was a 3 inch dia. tube, 2 feet long.....after our run on the salt we had about a couple of pints left in the tank.....
our engine was a pre-unit Tri. using a 750c.c. Morgo Kit, running thru a BSA close ratio gearbox.......
The bike has been retired and sold and is on display at some Texas truck stop....Oh, the shame of it all....
