Author Topic: Relieving the pressure on valve springs  (Read 2421 times)
Offline jdincau
« on: August 09, 2011, 06:21:59 PM »
Hi all,
     What is the consensus on relieving the pressure on valve springs when
the engine is sitting idle? We have not been racing every meet this year and
I was wondering. This is for the engine in the street roadster, the engine
in the modified is never together long enough to worry about it.
Jim in Palmdale
Offline Dynoroom
Re: Relieving the pressure on valve springs
« Reply #1 on: August 09, 2011, 07:25:02 PM »
Jim, IMO it depends.....  :-)   how much spring load (pressure open), how much lift, are you having valve train issues? etc.
A .600 lift cam with 350lb. over the nose no. A .850 with 850lb is a different story.
If it's a moderately built engine just rotate it from time to time. That's how I do it. If it's going to sit 8+ months you could back off the rockers if it makes you feel good.
But what do I know........
See you at the salt?
Offline jdincau
« Reply #2 on: August 09, 2011, 07:48:25 PM »
It's kinda in between .695" at the valve and 620 Lbs. over the nose.
No issues yet.
Yes Ken and I will have the modified there, north end of the SDRC pits if we can or next to Fred Blanchard if we can't.
Offline jimmy six
« Reply #3 on: August 10, 2011, 01:15:04 AM »
Jim, I always back off my GMC's rockers over the winter. When the engine is ready, like it is right now, I turn it over every other day with a 18" ratchet with socket on the crank.
