Author Topic: What size safety wire do you use?  (Read 3637 times)
Offline ol38y
« on: August 07, 2011, 12:04:19 AM »
I need to get some more safety wire and was wondering what size most people use. TIA :cheers:
Larry Cason
2010 BUB 1350 M-PG record
Online saltwheels262
  • LTA 7/2013
Re: What size safety wire do you use?
« Reply #1 on: August 07, 2011, 07:46:15 AM »
I use .032 inch stainless steel.
there is also .025 and .049 . don't know about other materials.
( I could be off a few thousandths on the .049 )
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline Anvil*
« Reply #2 on: August 08, 2011, 03:31:19 PM »
For my motorcycles I use .032 structural bits, sprocket bolts / brakes, triple-clamp screws and items like the oil drain plug. On cars, bolt-on oil pickups.
I do use .020, like when a tab-type points condenser (Lucas) is inside a distributor, the Cortina GT air cleaner with the nuts and washers inside (eventually they will make rattle noises a cylinder otherwise), or small screws holding some widget inside the oil zone.
Quite a few little items if it's a Baja racer but otherwise that's about it for safety wire.
Offline 55chevr
« Reply #3 on: August 08, 2011, 11:31:12 PM »
I suggest you review this link ... it is the aircraft standard for safety wiring.
http://www2.tech.purdue.edu/at/courses/at308/Technical_Links/Ac43-13-1B/CH7_7.pdf
