Author Topic: Verify Displacement?  (Read 4556 times)
Offline JoeRider677
  • FOIL HAT RACING - BIKES BUILT BETTER
    • Bikes Built Better
« on: July 16, 2011, 03:41:53 PM »
I'm a newbee. Should a record be qualified for and then backed up how does the inspection got to verify the displcement? I'd prefer not to be trearing my motor apart.
Foil Hat Racing
Bikes Built Better
SCTA Records 2011   ECTA 2013
MPS-BG   120.507     M-BF 140.507
MPS-BF   141.236      M-BG 146.19
M-BG      118.674      MPS-BG 165.01
M-BF      132.905       MPS-BF 170.32
LTA 2013
1 mile - MPS-BG 174.341
1.5 Mile-MPS-BG 184.09
ECTA 2014
M-BG 155.38
M-BF 149.00
MPS-BG 175.57
MPS-BF 185.33
SCTA 2014
How hard do you practice when no one is watching
Offline RichFox
Re: Verify Displacement?
« Reply #1 on: July 16, 2011, 03:51:32 PM »
If you can disable the valves and spin the motor, and it's ,not to close to the break, you may be able to pump it. Rarely possable on an OHC engine. Or if you have some device that will pass through the spark plug hole and verify the bore and stroke you will be good. After that it's tear down.
Offline Cook CMR
« Reply #2 on: July 19, 2011, 01:51:45 AM »
Hi
Car no 959 G/ Pro
Can the engine be sealed so as we can continue competing in different classes and measured at the end of the meeting
We have drilled holes to seal the engine
Offline RichFox
« Reply #3 on: July 19, 2011, 04:15:51 AM »
Yes. Other people have done the same.
Offline Avanti Kid
  • 2006 Member of Bonneville 200 MPH Club
« Reply #4 on: July 25, 2011, 07:43:01 PM »
If some engine CI is closer than 3 % of the engine limit, then pumping can not be used, so you would need to remove a engine head or even easier on some cars, remove the engine pan, they can measure from there to verify legal. Dave
PS, Dan Warner can answer this question better!
Original owner of 1963 Avanti; Age 84
2006 Bonneville 200 MPH Club Member
Canyon Country, CA
215.6 mph 289 CI Studebaker engine
Offline dw230
« Reply #5 on: July 25, 2011, 09:59:01 PM »
We try to use the pump as much as possible. JD Tone was able to hit the cid on the nose using the temp factor.
Each displacment check unique and I have a good crew working with me. Dave, when we drop a pan you can come measure it. I don't do that anymore.
Offline jimmy six
« Reply #6 on: July 25, 2011, 11:10:54 PM »
I learned the pump from guys who certify the NASCAR pumps (or did) only a few are torn down.....I can pump a 302 on a 305 max, or could, when I was doing pumping 10 times a day. Dan will remember the guy who pumped a 435 when he wanted 445. After 3 different holes he took a head off and we measured it 434. Seems like his builder put in the wrong crank and pistons...............JD
