February 03, 2012, 10:47:41 PM *
Pages: 1 2 3 4 5 6 [7] 8 9 10 11   Go Down
Author Topic: Mad Max Beyond Thunderdome  (Read 14768 times)
bobc
« Reply #90 on: July 21, 2010, 10:51:46 PM »
A 'lost' post from Windjammer.....
"little MAX has done one hell of a job with his NORTON. it's one fine cycle. as STAINLESS said the apple didn't fall far from the tree. he  seems to have the same talent of MAD MAX.... "
The WebElf
Web Elf
bobc
« Reply #91 on: July 21, 2010, 10:54:59 PM »
Hey, we're back.  There was a corrupt post that kept whatever 'page' it was on from showing up.  Through the modern miracle of computer science (ok, I admit it was dumb luck and Forum-forum prowling) the bad stuff has been whacked off.  Whew.
Web Elf
landsendlynda
Location: FOUR! Count 'em 4 miles from the salt!!! Life is Goood!
« Reply #92 on: July 21, 2010, 11:12:40 PM »
Bless your little elf heart!!
Lynda
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
« Reply #93 on: July 21, 2010, 11:16:41 PM »
Thanks Bob.  I guess the picture of Lenny I posted broke the server....
I will have pictures and maybe even video tomorrow.  We started the liner today, it jumped immediately to life but was running on half the cylinders, problem with the ignition module... new one here at noon tomorrow.
 MSA Lakester #1000 my fastest mile 245 and change, 84 ci turbobusa motor... but Corey's H/BFL record is still 3MPH faster than mine.
 Builder of Bike 278 1000cc APS-G,  Kids Red Hat Record 208.959 (old PS rules)
 Other kids A-G record 179.172  Josh O record 182.266
 Co-owner of the Amo Steele Streamliner, #1411... still sorting
« Reply #94 on: July 22, 2010, 10:53:32 PM »
As threatened, here is what has been going on
John, Lenny and I have been helping Max get the scooter ready for its first start in 2010, the year of Black Lightning according to my calender.  We moved it outside and started setting up the dyno equipment Max borrowed from Jerry Wilson.
Our first test will be to see if another picture of Lenny seizes the server again....
Then we throw in a picture of John
If the server holds to both, with Max directing traffic we shall be able to proceed
 rolleyes
maguromic
« Reply #95 on: July 22, 2010, 10:58:41 PM »
What a beautiful machine!!! I am simply in awe and always enjoy the updates. Tony cheers
« Reply #96 on: July 22, 2010, 11:02:16 PM »
Here is the dyno.  Max has made an adapter to mount it to the transmission.
The scooter is set up on wooden boxes and John attaches the "dyno leg"
Then the dyno is bolted in place
« Reply #97 on: July 23, 2010, 12:21:59 AM »
We got it all hooked up and decided it was time to start it to see if it would run....
http://www.youtube.com/watch?v=fwCCpFhQtY8
It did, kinda... the rear cylinders of both motors ran fine...  front cylinders not so much, you can see in the video that one exhaust is spitting raw fuel... no ignition.  Here is the problem, the ignition pick-up must have got a bit fried.
Of course there is not one in town, but a quick trip to Truitt and Osborne netted one by next day air.  Of course it was a little disassembly to get it out
« Reply #98 on: July 23, 2010, 01:18:12 AM »
All the parts are back together, and we have ignition
http://www.youtube.com/watch?v=VycGIDJqNPg
tomorrow morning we run a little water through the dyno, load the motor a little and see what happens
saltwheels262
LORING 7/11
« Reply #99 on: July 23, 2010, 02:26:50 PM »
[quote ... no ignition.  Here is the problem, the ignition pick-up must have got a bit fried.
[/quote]
better to happen on the trans dyno
than the big white one.
franey
max 10/07 - a/pf   d license
bub '08 - 153.697 a/pf   pump gas
bub '09 - 156.377 aps/pf  ran out of gear
lta  '10 - 158.208  2 much gear 2x
Luckyontheducky
« Reply #100 on: July 23, 2010, 03:55:50 PM »
 Keep up the good work!
« Last Edit: July 23, 2010, 03:57:39 PM by Luckyontheducky » Logged
jimmy six
« Reply #101 on: July 23, 2010, 04:20:33 PM »
Having the exhaust exit the vehicle like it shows going to have any effect on the handling?  Just watching the nitro funny cars move when the loose a cylinder makes me look at side exhause differently than I use too.. Just wondering if it makes any difference on a 2 wheeler.........JD
« Reply #102 on: July 23, 2010, 09:19:16 PM »
JD, not yet but as a 2 wheeler it has only gone in the 220s... currently running as a 3 wheeler and after the dyno sessions this morning it has a good chance to run the distance several times...
We made a check pull, putting a little strain on the chains and motor, about 150 lbs ft at 4500 rpm for 20 to 25 seconds.
http://www.youtube.com/watch?v=viU7oDp51Wk
The second pull is still processing so I'll have it in a little bit
« Reply #103 on: July 23, 2010, 11:04:08 PM »
Here is the second dyno pull, running about 4500 rpm and holding 250 lbs torque.  The #4 cylinder will be richened a jet.  This pull had a little larger pill in the return to lean up a bit from the first pull.  The motor sounds great I hope the video captures the sound.
Our Fire Bottle inspector was amazed... he is a sprint car guy and he just couldn't get his chin off the driveway
http://www.youtube.com/watch?v=QcLg4YJtA1I
4-barrel Mike
Any fool can drive a V8
« Reply #104 on: July 23, 2010, 11:45:44 PM »
Wow!   shocked
Go Max!   cheers
Pages: 1 2 3 4 5 6 [7] 8 9 10 11   Go Up
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
Google visited last this page January 10, 2012, 05:17:09 PM
