February 03, 2012, 11:03:53 PM *
Pages: 1 2 [3] 4 5 6 7 8 9 10 11   Go Down
Author Topic: Mad Max Beyond Thunderdome  (Read 14772 times)
1212FBGS
« Reply #30 on: March 11, 2010, 06:20:05 PM »
is that big ol chain gonna be in a oil bath?
kent
« Reply #31 on: March 11, 2010, 10:00:42 PM »
On both sides of the motor...
The HiVo that broke ran in oil from motors to clutch, the one on the other side that runs from clutch to tranny also in oil.  Max plans to use the BIG CHAIN on both sides.  The HiVos will be gone.  That is going to be a lot of weight slinging around but I'll bet it stays together.
 MSA Lakester #1000 my fastest mile 245 and change, 84 ci turbobusa motor... but Corey's H/BFL record is still 3MPH faster than mine.
 Builder of Bike 278 1000cc APS-G,  Kids Red Hat Record 208.959 (old PS rules)
 Other kids A-G record 179.172  Josh O record 182.266
 Co-owner of the Amo Steele Streamliner, #1411... still sorting
« Reply #32 on: May 01, 2010, 08:08:13 AM »
Well it has been a while since I made it to Max's with the camera.  He has made a few pieces, just enough to know what to do next.  Sprockets are made, but not welded yet, for the crankshaft and cross shaft for the clutch.
The big chain is big... just a little heavier duty than the old one.
There are a few clearance issues that must be resolved before Max can proceed, but he has a plan to start milling cases and making clearance.  Then he will know what is next.
« Reply #33 on: May 01, 2010, 08:25:19 AM »
This one shows the tensioner requirement for the chain... not too bad
And after that side is finished, there is the other side, the clutch to tranny chain.  Max has his hands full with plenty to do.
bak189
« Reply #34 on: May 01, 2010, 09:56:30 AM »
SO.....at which event will we be able to see Max's liner run......Cook's for approx. $15000.00 entry or
BUB's for approx. $600.00 (for FIM) .........will it be a sidecar or a solo liner..........the fans want to know!!!
Question authority.....always
Dr Goggles
« Reply #35 on: May 12, 2010, 06:20:48 AM »
Jon.... Jon.... Jon.... That ain't moonin'..... this is  shocked
er that'd be six moons...and a fly's eye by my reckoning , that guy on the right hand end .... rolleyes
Current Australian E/GL record holder at 192.015mph
« Reply #36 on: May 14, 2010, 07:55:31 AM »
Stopped in on Max a couple of times, he is making some progress with the motor repair.  The main repair will be the case cracks that developed when the chain was processed through the gears.  These are cases that Max modified and welded, so he is repairing it by welding the pieces back in place.
Here are a couple of shots where the cases separated.  The first one is obvious, this was an area that Max built up a large fillet weld when he modified the cases.
It is hard to see in the second picture but the weld area along the bottom is fractured
« Reply #37 on: May 14, 2010, 08:11:03 AM »
So the first thing is push the cases back together to close up the cracks a little.
Then Max ground the old welds out, kept pressure on the cases....
« Reply #38 on: May 14, 2010, 08:15:45 AM »
Then started heating the lump and welding..... and heating the lump and welding..... and heating the lump and welding.....
« Last Edit: May 14, 2010, 08:18:39 AM by Stainless1 » Logged
little max
« Reply #39 on: May 14, 2010, 11:07:57 AM »
The Master is back in his Zone.Thanks for the update Stainless.
Only time and money prevent completion!
« Reply #40 on: May 14, 2010, 11:27:05 AM »
I know Max is probably doing this already but when you weld something that has bearings in it,like his engine case, it is very important to make sure that only the case is grounded and that none of the shafts or any other parts of the case are touching anything that could make a ground. Even very small amounts of current going to ground thru a bearing can case the bearing to fail. I speak from experience.$$$$$$$
bak189
« Reply #41 on: May 15, 2010, 06:12:15 PM »
Still did not get a answer...... at which event will we see Max's liner run.....BNI....BUB....Shootout?Huh?
« Reply #42 on: May 15, 2010, 09:47:42 PM »
 shocked
If I knew I'd tell ya
 undecided
 cheers
« Reply #43 on: May 15, 2010, 10:14:33 PM »
bak, attend them all and you won't miss him when he makes it.
« Reply #44 on: May 19, 2010, 11:01:43 PM »
Bak, Bub... just got the email
Max is moving on, the sprockets I showed earlier were just pressed on the crankshaft and clutch hubs.  He took them down to an old friends shop, Performance Engineering, here in Doodah to have them welded.  The place is owned by Warren "Jelly" Wilhelm, I didn't get a picture of Jelly, but his welder and fabrication guy, Andrew Tolle is shown in the picture with Max.
Very interesting place to visit, you need a US made english wheel, he makes them, dropped axle for your sprint car, makes them too, dual carb manifold for your old 60 HO V8... yea, makes those too.  This is what you see when you walk in the door...
Did you notice the big picture on the wall in the first picture?  Wichita Speedway, starting field and drivers, looked like a brick track... 1915
Place was full of toy race cars, and lots of stuff.... even had a Speedy Bill bobble head  grin
Pages: 1 2 [3] 4 5 6 7 8 9 10 11   Go Up
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
Google visited last this page January 30, 2012, 04:28:46 AM
