Boeing did all the R and D on the scoop
and its transition to a 3 inch duct. It came from a burned engine pylon that was being repaired. Since it was surrounded by burned skin, it could not be reused and was condemned into my trash can. We built a panel to put it on the car, just trying to put fresh air in the motor area. It was almost impossible to paint, any time paint was sprayed across it the paint would just shoot out the back. We decided we needed to build a closed induction system. While most believe the NACA is ineffective at low speeds, we have recorded pressure in the airbox at WOT starting about 190 MPH. The pressure rises with speed. We had attempted to double the air by using 2 ducts, thinking we could get more pressure, lost all the pressure, guessed it was running out the other side. The key to the duct efficiency is the wing, stop by to look at it at WoS.
Sorry, it an innie not an outie
