February 09, 2012, 08:30:09 AM *
Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15   Go Down
Author Topic: Visit to Thunderdome  (Read 48232 times)
deejay499
« Reply #150 on: July 28, 2008, 04:52:15 PM »
Hi all. Just caught up with the news on the site. Absolutely brilliant! Well done Max. Makes us very proud to be Vincent owners with a common bond. Looking forward to seeing you and the liner at Bonneville. Good luck and best wishes from the VOC and the sidecar section. Cheers, Dave Johnson
landracing
Guest
« Reply #151 on: July 28, 2008, 08:55:42 PM »
Well by the view of the second video, You can tell who the real men were and who the pussy was... Look again at the first to bail out.... And a hint,,, he was the only one wearing those girly ear muff's...
Good video's stainless and Max I hope you reach your goals this year.
JonA
« Last Edit: July 28, 2008, 10:39:13 PM by landracing » Logged
38Chevy454
« Reply #152 on: July 28, 2008, 10:36:37 PM »
Great job, the video sounds awesome.  Looking forward to see and hear it in person.  Keep up the good work.
« Reply #153 on: July 29, 2008, 05:11:48 PM »
Dropped in on Max today, caught him working again.... The clutch mister and the cylinder head misters are made and installed.
First a couple of pictures of the clutch mister...
 MSA Lakester #1000 my fastest mile 245 and change, 84 ci turbobusa motor... but Corey's H/BFL record is still 3MPH faster than mine.
 Builder of Bike 278 1000cc APS-G,  Kids Red Hat Record 208.959 (old PS rules)
 Other kids A-G record 179.172  Josh O record 182.266
 Co-owner of the Amo Steele Streamliner, #1411... still sorting
« Reply #154 on: July 29, 2008, 05:58:00 PM »
And then 2 pictures the cylinder head misters on the exhaust side of the heads... the ones on the front engine are too hard to see...
Then the manifold for the front cylinder misters....but there is a story for the last picture... it is the distribution manifold for the rear cylinder mister grin
Years ago Max was racing a Vincent and had a part that broke loose on the bike, he used a little wire to hold the part on, the bike made a 168 MPH pass, the fastest it had ever gone.  Now Max is not superstitious, but....  undecided every bike he has built and raced since has one part that is wired on.  Sure it could have been attached with a bracket, or even a plastic tie, but Max likes to use a little wire now and then...  rolleyes
« Last Edit: July 29, 2008, 05:59:50 PM by Stainless1 » Logged
« Reply #155 on: July 29, 2008, 11:38:57 PM »
Waiting for processing on u-tube again, it seems a little slow, but I am new to u-tube and frequent the "worlds fastest website"
OK, they finally got done... Sorry guys, we didn't run the deafening tearjerkers... but I did get Max to show off his scooter a little.  The first is the Skid Test, I accidentally caught us pre-checking, so I threw it on the start.
http://www.youtube.com/watch?v=eH8RGMPixZk
The next is the parachute test
http://www.youtube.com/watch?v=X5N4cPUvlwY
Then the water spray system test with a quick switchology lesson
http://www.youtube.com/watch?v=ZnQPa7VQ6pY
Most of you have not met Speedo... WAIT...WAIT, this is not Max in a speedo,  shocked  tongue this is the Black Lightning's Mascot.  grin  Here is his intro...
http://www.youtube.com/watch?v=1PLwiQ7dTns
I even got Speedo to pose for a quick photo op....
isiahstites
« Reply #156 on: July 30, 2008, 12:10:57 AM »
Thanks for the videos, it was cool to see everything work.
A few questions:
1. How much water do the liner hold to keep everything cool?
2. Why spray the front tire and is the cooling just to save the tire?
3. Do you cool the rear tire?
Scott
Kansas Bad Man
« Reply #157 on: July 30, 2008, 06:54:04 AM »
A few questions:
Scott
Scott,   First the front tire cooling.  The cooling water hopefully will help in keeping the 21" tall Goodyear from chunking.  I'm not sure, but I think Denis threw some rubber off of his at 354 mph.  Sam only had one tire left, and he's the one who first sprayed water on the tire to cool it down.  The Vincent streamliner has the aero, the horsepower, (573 hp, 385 ft. lbs. of torque, dyno test) and a good traction coefficient; with that combo it should nudge 400 mph.  The front tire is the weakest link to achieve that speed.
                                          Max
Kansas Bad Man
« Reply #158 on: July 30, 2008, 06:59:53 AM »
A few questions:
Scott
Black Lightning has 4 separate water tanks.  The front tire cooling tank is a little over one gallon.  The cylinder head spray cooling system has a little over two and one half gallon tank.  The cooling tank for the clutch and chain has a capacity of one and three quarter gallons.  All of these tanks are obviously total loss.  The cylinder muff cooling tank is five and one half gallons.  This tank's BTU can be changed by adding ice if required.
                                         Max
Kansas Bad Man
« Reply #159 on: July 30, 2008, 07:02:09 AM »
A few questions:
Scott
I don't cool the rear tire, not even close to being necessary.  The 700X18 Firestone will go 435 mph, no problem.  Same tire Al Teague ran.
                                        Max
Kansas Bad Man
« Reply #160 on: July 30, 2008, 07:39:32 AM »
Correction of the above speed.  It was 162.36 mph.
                                                   Max
« Reply #161 on: July 30, 2008, 06:57:35 PM »
                                                   Max
Well, y'all know that dang Stainless is prone to exaggeration....  rolleyes  I'll bet if Max had wired on 2 parts it would have gone 168  wink
See ya Friday Max
« Reply #162 on: August 01, 2008, 10:50:42 PM »
Stopped by to see Max today, darn guy was still working. the first thing I noticed was the scooter was covered up, with brown paper... Max's Machine Shop had been converted to Max's Body Shop...  undecided
Max was working on the cockpit body section, he had changed the body sections and had to blend a little, then the finished part needed some fiberglass reinforcement on the edges.
These are body lifters... Max needed something that would make it easier to hold the body up while the guys installed fasteners.  Yes that part of the body is not that heavy, maybe 35 lbs, but it is awkward.  Mad Max drew a sketch and they appeared, I guess we will see if they work...
« Last Edit: August 03, 2008, 09:53:12 AM by Stainless1 » Logged
« Reply #163 on: August 04, 2008, 05:18:18 PM »
Well, the body shop was turned back into the machine shop over the weekend.  Max took the last piece of body to the painter late Friday and was headed over to check on it when I left his garage.  Yes, Max usually paints it, but he is running out of time, and the cottonwood is still flying around his paint booth  rolleyes
But back to work, here are a couple of shots of the Clutch to transmission HyVo chain cover (primary, well kinda) that Max finished this weekend.  Remember that was the last major job I mentioned Max had left.  He needed to accommodate the larger pilot shaft bearing on the M21 input shaft. The red anodized parts are where the outboard carrier bearings are located.
While we were there, Trey (my grandson) and I helped Max bleed the brakes.  It was slow going until Max mentioned there were 4 bleeders on the big Wilwood brakes.  It's hard to get good help....  undecided But the beast has brakes now.  Getting closer all the time.   cool
saltwheels262
LORING 7/11
« Reply #164 on: August 04, 2008, 05:28:39 PM »
nice brightwork, great bike. good luck .
max 10/07 - a/pf   d license
bub '08 - 153.697 a/pf   pump gas
bub '09 - 156.377 aps/pf  ran out of gear
lta  '10 - 158.208  2 much gear 2x
Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15   Go Up
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
Google visited last this page January 17, 2012, 08:42:02 AM
