I've found that with enough reading, the rules become clear. I think that my current confusion is caused by ignorance of the terminology....
"All traction bars and trailing links shall have a metal sling near the front attaching point with a minimum of 1/4" diameter."
My rear suspension consists of a traverse buggy spring held in position by ladder bars, each of which have two bolts at the axle and one at the forward attaching point.
Do trailing links have just one bolt at each end? For tech purposes, are my ladder bars considered trailing links? (Notice the ignorance)
If not, would "slings" be recommended anyway? I'll probably do something, even if not required.
Ok, next part of the question: "metal sling....with a...1/4" diameter" to me connotates round, like steel cable???
I mocked up a loop of cable using red 10-gauge wire (see Cable lower view.jpg & Cable upper view.jpg) through the x-member & around the forward end of the ladder bar. This doesn't seem really viable, so...
I mocked up a bar under both ladder bars running from one leg of the x-member to the other (see Strap lower view.jpg and Strap upper view.jpg) - currently 1" x 1/8" for ease of mock up. This seems like a better solution than using cable. Does it meet the letter of the rules?
Any thoughts, comments, criticisms welcomed.
